H3 JKS 2001 Sway Bar Links
bubbas3rd
TX
Does anyone have a picture of these installed on H3 with 4 in Rancho lift????
LOL, I have a few. They work great and highly recommend them.
bubbas3rd
TX
Awesome! Mine did not come with 2 pins…and the screws they sent were too short since I’m not using the bracket! Guess I will order more pins and clips!! You have been a great help, as always!!
Yes, I should said that, I ordered 2 extra pins and clips.
bubbas3rd
TX
Bare with me…just a girl trying to figure this stuff out…what part is this, and could I fix it on my own?? This just happened….
Gpcalero
SW Florida
Bubbas3rd,
I believe the lower ball joint you are using is an AC Delco Professional piece. I have found that those come with a greasable zerk fitting that has clearance issues with the cv boot. You should clean up the grease in that area and check the clearance between the zerk fitting and the cv boot first. If it is hitting then you will need to replace the fitting with a low profile fitting and give it a pump of grease, as well as replace the cv axle OR the boot if the axle isn't destroyed. You can certainly do this yourself, but I would have somebody help you who knows what they are doing for your first time.
I ran into this issue while installing my Rancho and was replacing the upper and lower joints while I was in there. Luckily, I noticed the issue before putting the truck on the ground. If that is the case, then you oughta be upset with whoever replaced the balljoint.
Gpcalero
SW Florida
Awesome!! Do you know of these for H3 in stock height? I want to install it in my H3 alpha
Thank you!
Oscar,
I run these on my Alpha as well. All you should do is measure your existing links and buy a JKS end link that is adjustable to that length. I think the Rancho uses 4" end links. Not sure about stock ones.
