Vdawg’s H3 build
Vdawg1115
Oakland, CA
888F82CC-3FA3-4C18-AB09-AF5A39AF7F48.jpegAdding an additional crossmember up front
Vdawg1115
Oakland, CA
DEEF92A9-9B7C-49FE-8917-1E3F5AC97776.jpeg1DB00262-6428-461B-9B6B-D1F004B6B51E.jpegMade some minor ride height adjustments. Also decided to go with High Angle Driveline for the driveshafts. We decided to go with 1350 ujoints on the tcase output….so ended up not needing the Thorparts driveshaft adapter after all. This will also mean modifying the crossmember to clear the larger ujoint and CV. Just waiting on the driveshafts now
Vdawg1115
Oakland, CA
63C94E05-08D9-46CF-A6DF-7B6FA359F161.jpeg9E1FE125-B86B-4371-BDF3-F53B24D61D3F.jpeg96FAA92A-C11B-400E-B221-0CF35CFA4D69.jpegNothing new to report. Coming up on 2months waiting for the driveshafts from High Angle Driveline. Not to mention the whole project started in April. Almost a year on that also
Vdawg1115
Oakland, CA
Well the front driveshaft showed up. Rubs the crossmember a little since we went with 1350 u joints. We’ll notch and plate the crossmember to clear the CV. Should be another week or two for the rear driveshaft
61678B9F-1E1F-405B-9572-EA29956CF1BB.jpegED5CA98C-C019-4126-BCFD-8E67E7873406.jpegE0589AE1-CAE2-4124-A2FB-E1D5CAF2C474.jpeg6FBD544D-B640-4388-B5E8-B33E62FACCA9.jpeg
Vdawg1115
Oakland, CA
Rear driveshaft installed. Will probably get to road testing this weekend hopefully…..current rains might change that though. Exhaust still needs to be done among other little details
C6B6FB32-7B20-4111-BD28-C81E47929FA4.jpeg8D0FA497-AD40-4CCC-A48A-B66764BC67AB.jpeg5822A5E3-84F5-432C-80E1-5E21D8A9189D.jpegDA5098F0-462B-4BAA-9C0D-F4C3435E9E47.jpeg
Vdawg1115
Oakland, CA
Also added a sort of skid plate that connects to two link mounts. Will need to flex it out and see if the notch is bigger enough to clear the front driveshaft at full droopEFC15333-86DC-4792-837C-96EEC1086883.jpeg470C6D2C-A1AB-4180-9AA1-DF7DF98F2995.jpeg16828B07-9CB5-444C-9E8D-9DBE4006541B.jpeg
jakesz28
Cabool MO
Definitely going to need details on this!
Sent from my SM-G998U using Tapatalk
I had picked up an 05+ super duty 60 a while back. Was going to retube it to passenger side drop. Was looking at Busted Knuckles 14 bolt housings. Then I found a local 4wd shop selling retubed axles. So ordered a 14 bolt, shaved front steer axle, uses SD C's and knuckles, so you can run big U joints and larger short stub axles. Was quoted 6 week to build the housing.
Going to start ordering mounts, dom, ect.
