Hummer H3 - Replacement Rear Frame Shackle Mount
jphh20
CT
I am looking to cut off and weld on a new frame rear shackle mount. I have found this one online and curious if anyone knows which would be a best fit to replace the factory frame mount.
I was thinking of the 3" wide x 1/2" ID. Would this fit?
Appreciate any help that you can offer.
https://www.ruffstuffspecialties.com/R1253.html
jimmy p
detroit
jphh20
CT
I just did the same thing but made my own frame side mounts. Here are the bushing and tubes I used for reference and used the stock h3 leaf springs with them.
Thank you for your response. I found a place that will cut off my old mounts and install these.
Alan45
Findlay ohio
My mounts are terrible can you direct me to new ones for the rear rusted badly
Wow..you're right. Those are terrible. You'll probably have more metal work to do once you get the old ones cut off. I'm sure you can modify new or fab-up shackles once you get into it. Love to see the finished product.
Korby7
Utah
Eventually I'll be swapping out for the ones in this link.
e0308jr
Muskegon, MI
I have one of the brackets on the other end of the rear leaf spring. I can not find a replacement.
Thanks
