- Scottsdale
My H3 has been using oil for a long time, generally with blowby on higher demand periods, like long steep highway climbs and off road in low range. Between the highway drive from Phoenix to St. George (400 miles) and the off road use over four days in UT, I had to add over 3 quarts of oil. This is using Mobil 1 5W-30.
I decided to add some snake oil as the last quart of oil - Lucas Oil Stabilizer. After that, I drove home to Phoenix and experienced strong headwinds most of the way home, reducing my mpg to 9 mpg vs. my typical 12-13. My engine got a workout. I promptly forgot to check the oil until today and found that I didn't use any oil at all during that trip. Thickening the oil did the trick. Reading the bobistheoilguy threads, they HATE the Lucas stuff (they hate most additives) but specifically pointed out that it may be prone to foaming as there are no anti-foam agents in there like there is in motor oil. They had a simple test for this, and it may not reflect real world results. But at $13 or so per quart for the Lucas, I'd rather see if a thicker grade motor oil will yield the same results as I got with the Lucas product. (Because $6 is way too much extra to spend, haha.)
My next oil change will be to synthetic 10W-40 to see if that works for me. I considered Delvac diesel oil like others are running, and some tout the benefit of the detergents and the zinc, but I also read conflicting reports that the zinc can harm catalytic converters and I'm excited about damaging that over a few (or many thousand) miles.
So, I'll change the oil in the next week or two and see how that goes for usage.
