No reverse
reaper
Denver, Colorado
All of a sudden my h3 (2006, 120,000 miles) won't go into reverse. Drove to the store and back, reverse worked at the store, and driving back home we stopped to check if a guy was ok (big snowstorm today) and it wouldn't go in reverse.
I'm thinking the main culprit is jealousy, I spent some cash lifting my jeep. Other than that, any ideas? I tried shifting to 4high and back, it shifted but still can't get reverse.
reaper
Denver, Colorado
Codes:
reaper
Denver, Colorado
Google says: Resolving a P0741 code might require you to replace the torque converter clutch solenoid (TCC solenoid) of your vehicle. Similarly, you might have to replace your vehicle's transmission control module, also known as a TCM.
Is that the likely culprit? Or is this just part of a f'cked tranny? I really have not driven it that much this year... was driving it in wet snow when this happened.
Teahead
Tacoma
YOu still running stock battery terminals?
The PO of my rig told me that his newly built trans mission wouldn't shift out of 2nd or 3rd.
Took it to the shop again and they pulled the trans and rebuilt some more parts. Didn't help.
Until he put on new Stinger battery terminals.
650Hawk
Don't just "screw with the battery". Cut the damn stock battery terminals off and throw them as far as you can. Then install some good ones. These trucks are ridiculously sensitive to any and all voltage variations, and can throw a multitude of seemingly unrelated and random codes and issues. Trust me on this. Even if they look and feel good, they AREN'T!!!!
reaper
Denver, Colorado
I haven't run stock ANYTHING for a very long time. Yeah they aren't stock. But since I'm throwing codes, I don't think it's the battery. And yeah, you're right-- my H3 is really sensitive, you are SPOT ON!!!! "These trucks are ridiculously sensitive to any and all voltage variations, and can throw a multitude of seemingly unrelated and random codes and issues." ... adding, including weather, altitude, sunlight, relative stress of the driver in case he/she should be stranded, a direct correlation to the inconvenience caused to the driver, phases of the moon, current astrology report.... and on and on!
Doc Olds
Boat Town MI
2006s do not have a TCM, those were used 2008+. 2006 & 7s control the AT with the PCM.
Common failure of the 4L60E is ===== No Reverse. Usually some slipping in any forward gear along with that or right after.
Doc Olds
Boat Town MI
Very interesting these crappy azzed OEM Battery Terminal Connectors and using Stingers to correct electrical Gremlins. 😜
reaper
Denver, Colorado
K. I'm going to punt until after Black Sheep Week. Yikes, not sure I want to swap a tranny. Any cheap way to do this? She's got 115k miles.
reaper
Denver, Colorado
So after talking with dealers, searching forums, all that-- I'm going to bring it into the garage, drop the transmission pan, and look at replacing the solenoids with something like this: https://www.mts-performance.com/product_info.php?products_id=424
That *could* do it, I'll also just swap the fluids when I'm at it, and we'll see what happens. There's no way I'm paying thousands to a shop on this at this stage of it's life. Worse that can happen is I wasted $230 but that's what the codes say isn't working right now. Not super confident in the fix but it's what I can afford (after spending too much on my jeep last month). Will take a but before I get started though, I need to move a jet ski from the garage. Maybe a summer project. The H3 is a third car for the house right now, so not super urgent.
True statement!! The PO of my H3 installed el-cheapo battery cable ends..and they were awful. Had problems too. I soldered a set of THESE on the ends of my H3's cables. They work great and look fantastic. I wrapped some red tape around the Pos side. Grounds are super important, so I also added a couple additional into the ground clamp before soldering on the Neg terminal, which I attached one to the body and the other to the engine. And got a new interstate battery. Haven't had electrical problems in years.
But that might not be your issue.
Only 120k?! That's like NEW!! Cheaper than a new Bronco or Rubicon...
reaper
Denver, Colorado
Ok, after NOT working on this for like a year-- I'm starting planning for the fix, wondering if I shoul djust go for a new tranny-- around $2000 after shippping from www.fraserengineco.com. The solenoid thing may or may not fix it, and there's also valce things-- and parts aren't that readily available from GM (a lot of the solenoids and valves are discontinued). Thoughts on just replacing the tranny? Seems like an easier way than diagnosing randome things. How easy is it to swap the tranny in my own garage? I replaced the TCase, is it about the same size job, or is it a monster?
CaseyS
Louisiana
If you are gonna spend $2000 on a transmission get a few local quotes to have your transmission rebuilt. If it drives in forward and you can get it to a shop you will save a lot of headache. I would think you can get a rebuild quote with some warranty for the 2-3k range.
That said I have dropped mine many times. I recall on the stock trans you will need about 36" of extensions to get to the bell housing bolts and will need a transmission jack to be able to lower it down. Once the transfer case is down you just have the shift cable, wire harness, vent line, tq bolts and then bell housing bolts to get it down. Last time I dropped it I had it on the floor in under 4 hours working by myself.
reaper
Denver, Colorado
Ok thanks for the advice-- first shop I called offered a 3200 rebuild. At that price diff it's worth paying them as it would be a struggle and a very long gig for me. Will call around this week...
reaper
Denver, Colorado
I'm getting consistent 2800-3200 rebuild prices. Found one with a 3 year 36000 warranty... I think that will do. Yeah I need to resurrect the h3 so it can intimidate my jeep.
reaper
Denver, Colorado
Here's the repairs done to my transmission. $3200 for the rebuild. Glad I took it in as it had more to fix than I could have done.
