Front end maintenance blitz:
lfootmatt
AZ
2008 Alpha, 135K ish miles, 4” Rancho lift with the diff and lower bushings replaced already, mostly desert SW life. Ride is pretty super soft and sloppy due to shot Rancho 4 -way shocks that came either the lift kit, installed when the vehicle was new. What shocks???
I’m doing CV half shafts and power steering rack tie rod boots anyway. What else in the front end should I do while I’m in there? Maintenance and mod suggestions are appreciated. I want to improve performance and durability for running some AZ trails this fall/winter.
Thanks!!!
Happy Hummer
Wisconsin
Well last fall I purchased another H3...its an 08 base model. Anyway the previous owner was way ruff and lacking on things, thank God not all things, but enough.
I replaced the entire works up front.
*bump stops
*cv 1/2 shafts
* brakes (rotors, pads, hardware, etc.)
* hubs
* sway bar bushings (these were literally hammered)
I proceed to check every item I could check and tore the front bumper off as well.
lfootmatt
AZ
Yeah, the desert has done a number on everything rubber, Bushings, grease boots on most of the front end components are cracked or just shot, probably going to try and do everything to improve the drive-ability.
What shocks are we going with for a Rancho 4” lifted Alpha? I’d like good manners on the trails and some light rock crawling ability.
SAS In the future, just not for a couple of years.
