HELP..... Brake pad issue
Pappibri
Cohoctah, MI
Are AC Delco pads good enough to run on our rigs...? The parts department at the dealer told me OEM ones are 180.00 front and 170.00 for the rear. He also said that most of the Hummers that come thru there just go with the AC Delco ones, that sell for 88.00 for the front, and the same for the rear... Are they a good enough pad? They are ceramic... Please chime in, I need to do the brakes before I go camping. I will be pulling my popup and will be going to Silver Lake Dunes, so I want to make sure my brakes are right.. Thanks guys...:huh: What ones should I go with?????
I think the AC Delcos are the best for our trucks. They bite really well and last a long time. You can buy those pads online for $50-$60 per axle. Also, GM periodically offers deals for $99 per axle for new brakes installed. Actually, right now they are offering it for $75 per axle after a $25 mail-in rebate: http://www.mycertifiedservice.com/auto-service-offers/index.jsp#offer_row6
See attached
  • offerID=newBrakes.pdf
Chook
Brisbane (Australia)
I upgraded mine to EBC Yellow pads and they are great. Apparently the EBC green are the oem equivalent. You can get a quote from USA direct or direct from the uk manufacturer.
Xlr8n
Midwest
NAPA Safety Stop pads are equivilant to OE and are about $52 per axle.
NAPA Ultra Premium have a higher ceramic content and are about $75 per axle.
I put on the Safety Stops last fall and they've worked well thus far with minimal brake dust.
MaxPF
AGNTSA
The dark side of the globe
I generally run Bendix pads on my stuff. Do NOT use their "Global" pads - They're the budget line and are imported crap. I have never had a complaint from anyone when I used Bendix pads on their vehicle. I should point out that not all types are available for all vehicles. For instance, my D60 front axle has only TitaniuMetallic II's and Fleet MetLock available, while H3's have everything except Fleet MetLock available. According to their site, the Global pads are listed as "Good", TitaniuMetallic II's and CQ are listed as "Better", and CT3 and Fleet MetLock are listed as "Best". I've only used TitaniuMetallic II's and CQ's. Never used the CT3's, but they're supposed to be the best. I installed the Fleet MetLock on my D60, so I will see how they work out once my rig is rolling again.
Raybestos has a good reputation for their top of the line pads as well, but I have an easier time getting Bendix around here, so that's what I use. If Raybestos were easily available and the Bendix weren't, I'd have no problems using them. Both are OE suppliers, although I don't know if either supplies the pads for GM. Obviously, pads from GM should work fine, but you pay a premium. Parts stores branded brakes are hit or miss... usually miss. They could be made in North America, or overseas, and they could work fine, they could squeak, they could generate lots of dust, they could eat rotors, or they could disintegrate. I have had them do all of the above at one time or another, which is why I stick with what I know works.
I had the top of the line Raybestos on the H3 for a while and I don't think they were as grabby as the OEM pads. I removed them well before their end of life
Pappibri
Cohoctah, MI
Ended up grabbing the AC Delco Advantage pads at the dealership. They were only 78.00 a pair... Back in school full time at 46 with wife and 2 kids.. Cant afford the OEM ones right now.. I would have like to get the OEM pads and rotors but that is not in the cards at the moment.. I hope my rotors is good enough to slap the pads on, and if they need to be turned, I hope they have enough on them to do it.. Will see I guess.:huh:
