High Five H2
- West Texas
how did you adapt it to your crossmember?
Dextron 6. Only
Main spare part for my Hummer while off-roading - sattelite phone !
Man oh man I hope this works out! I could really use a better trans in my T!
3 transmissions don't lie... The 5.3 with super charger and 37s is too much for the 4L60e!
Calling BS on what? The 3 transmissions?BS I build 4L60 to handle 500+ With 40"s ( not cheap but well worth it)
White T is getting upgrade in next couple of weeks, it's TC I am worried about. And it will be getting a blower and 40s before next summer.
I own AAMCO if you build it to "competition specs" ~$2500 (parts only)for me (~6500 for plain customer)it will hold 500+HP. Your blower is ~420hp. I have done it on GMC when I got it and 2 years later it has no issues.
plus TC is a pos that will go first. 2 trucks 4 TC.
Just an update:
Got the transmission installed and filled up the other night. Fired it up and Reverse gear worked great. Nothing when in any of the Forward gears. Everyone says thats a communication protocol issue between the 2011 transmission OS and my h3 2009 OS.
So, got a GM technician buddy to come by today and reflash my transmission (TCM) to a compatible OS. Tried it 4 different times, and it always error'd out at the very end.
Now, nothing works... TCM is a brick. It won't even let me take it out of Park now, and engine light is on showing no communication with TCM.
So.......... in the process of trying to find out which TCM/Valvebody part number to order. Don't want to brick anything else; at $500 each, those TCMs get expensive.
Do you have tuning software?
The brick at the last step is the difference in the last 8 bytes being written to the one vs the bootloader programming the last 8 bytes itself.
You will need an ecm on the bus or terminate the can bus with a 120 ohm resistor to flash a tcm on a bench harness
Good luck
Ryan
You did nothing wrong other than cross the 2 types of t43 controllers. 2009 and older and 2011+ with 2010 being a mixed year some using the older style and some new style.
The pcm uses a bootloader to reflash. The last 8 bytes are used to tell the tcm that it has a valid calibration file present.
A 2009 tcm and reflash should be fine. The tcm module you have should be able to be recovered if you reflash a 2010+ file back into it.
Ryan
Ryan
