awalsh
- New Jersey
Just want to clarify something.. Axle seals were leaking badly but the new crossmember bushing really helped out a lot. Just had my drivers side wheel hub replaced and the shop told me that they would need to put a new wheel hub in the passenger side since they need to disconnect it to put in a new axle seal. Is this true? I thought you could just disconnect the steering knuckle and pull out the cv to replace the seals. I don't want to spend $400 on labor and have to buy a new wheel hub for the passenger side even though it isn't bad. Or could they mean that the cv is most likely frozen into the wheel hub not mattering if it needs to be replaced or not. Input is appreciated!
