FJ4overland
plug reading.... at first glance, I thought I had an oil fouled plug in hole number 2.... but no, that's not oil, that's simply carbon.
5 of the 8 plug were cracked, that plug - the fouled one - wasn't cracked... that means that 6 of 8 cylinders were misfiring, not firing at all, or having a low-voltage moment....
time to fix a couple issues....
so there's supposed to be a gasket under the handle - if not, paint chips... and it chipped, oil plug seal to the rescue
and these leak.... which I thought I fixed before with silicone... nope
gasket made
So after the last run, there were several issues that I simply need to get addressed. one was a persistent fuel smell, another the exhaust leak, the 02 sensor (again) is acting up, and I've always thought this thing gets terrible mileage for the set up...
I've not been a fan of the Holley replacement TBI, but it was what I had and my hope of a replacement either being found (I have one, somewhere) or found at a swap meet just wasn't happening so today I went to the wrecking yard, spent $40 on these
the issue with the holley (the biggest issue) is the way they hold the injectors in place. GM used a bunch of screws to hold them down, the Holley just uses the air cleaner hold down.... to say it's inadequate is an understatement. It's worse thing is it doesn't stay sealed - it will do a nice spray pattern for a bit, but it will dribble and drip.
I cleaned up the TBIs, picked what looked like the best (it's the newest) and slapped it on
and I think the IAC is sticking, but it runs again (more messing with tomorrow)
which brought me to an issue or two I didn't realize
the is the old base gasket.... I think it's been leaking
back side doesn't look bad but see how close the witness mark is to the hold-down bolt? one of the bolts has crud from where it's been leaking up the bolt.... vacuum leaks galore
which I was all ready to take the blame for until I saw this
Holley uses a larger butterfly, it's been hitting but what's worse is that would create a tortured path for air and fuel to flow into the motor..... and of course, vacuum leak, uncontrolled fuel entry and I am hoping that I've found the source of what's killing my O2 sensors.... we will see, first step is reconfigure the throttle cable the replace the IAC....
Mr_Rich
Yucaipa & Santa Maria
Interesting; I'm familiar with TBI engines since I've replaced three of the four that were installed in my '89 K1500 EC. One of the simpler computer controlled engines to work on and I get great gas mileage in mine.
Mr_Rich
I was mainly noticing the four barrel manifold with the TBI adapter. I don't think that would fly in Calif. otherwise I might try it. I have a Hypertech chip and headers on my engine and that does it for me. When I swapped in the fresh(er) engine five years ago the (stock) roller cam made a big difference too.
it's a 1971 Land Cruiser - there is no emission check, even in Kalifornia.
so a bit of an update
first I need to fix the leaking spacer... of course, with no gaskets, this doesn't work so well
but, these came too...
so I installed them
Interesting, so instead of running long breather tubes up to a high point, it just uses those? Where did you find them?
so the base plate... I'd forgotten that it was a quadrajet, vortec intake so it didn't work, so time to fix... first, the problems
problems solved
only one of these gaskets worked, I had to make the other (mostly because I didn't want to spend another hour driving to and back the auto parts store)
it runs a lot better.... hopefully it'll also find some fuel economy
finished up
replaced the chip and o2 sensor last night. I have a 6A sitting on my shelf that I think I'll now replace the OEM controller chip with the MSD... it runs a lot better now, but multistrike should only helpfinished up
checking clearances
like this clearance
fixed
line up, clean up
weld up
and it fully turns
one of the big reasons for this effort is to get a better turning radius at full stuff.... once I get the parts for the high-steer cross shaft (probably Thursday), this bit is done then onto all the other stuff
