- Bellflower, CA
I am prepping for my front end rebuild soon and I have already bought some of the parts. As I researched the parts I could not find 1 spot with all the part numbers together. I so thought I would try and put together a list of what I have found so far. Please add any part numbers or opinions of the manufactures parts. Some may be better than others but I have found that prices can be significantly different such as the hub assemblies, $140 a set for AM Parts to $250 each for OEM.
1. CV’s – Cardone Select 66-1417 – 3 each
2. CV axle seals – AC Delco 290-297 - 2 each
3. Inner Tie rods 16mm – Moog EV800609 – 2 each
4. Outer Tie rods 16mm – Moog ES800762 – 2 each
5. Sway bar links – AC Delco 45G20693– 2 each
6. Lower ball joints – AC Delco 45D2432 – 2 each
7. Upper control arm Left side – Dorman 521-949 – 1 each
8. Upper control arm Right side – Dorman 521-950 – 1 each
9. Lower control arm bushing front – OEM 15088365 – 2 each
10. Lower control arm bushing rear – OEM 15088366 – 2 each
11. Hub bearings – OEM 15874836 – 2 still need
12. Alpha T bars – OEM Left side 93357121 – 1 each
13. Alpha T bars – OEM Right side 93357122 – 1 each
14. Rotors and pads front & back – Power Stop K2820 – 1 kit
15. Trailduty extended bump stops - TD-BSH3 - 1 set
16. Scorpworks front axle end brackets with new bushings. - 1 set.
