Got bored this weekend so made some improvements!
Bananatank
Hammond,la
Was bored this weekend so I did some cosmetics on the h3. Plastidipped the wheels, the emblems and cranked the torsion bar. What do yall think?
Bananatank
Hammond,la
Okay need some help guys. There is probably some super easy way to check but I would like to play music from my iPhone/iPod, and I don't know if the previous owner happened to install something aftermarket capable of doing this. Im still running the stock radio but i didnt know if the previous owner set up some Bluetooth of some sort. Is there any way to check this to see if the previous owner installed something aftermarket for the radio? Any help is appreciated. Thanks
poncho1965
Ridgecrest, California
If it's the stock radio, there are no provisions for iPod, etc. I bought one of Schwarttzy's adaptors and that plugs inline with the sat radio. Works fine, but I don't use it as much as I thought I would.
Mike
I swapped the stock head unit for a Kenwood just for that reason. And I used a single din so I could stack it on top of my cobra cb. They both fit in the double din space nicely and I hardly listen to the radio. My phone is always plugged in streaming Pandora. Schwartzys aux input is the only one I've seen around.
Bananatank
Hammond,la
I ask the question because on the roof on my hummer there looks as if there are wires on the roof that look aftermarket. Idk if yall have this also. Another question i have is that after cranking my tbar it has definitely decreased the ride quality. When I hit a small bump it jerks. Idk if yall know whats going. But helps appreciated.
How high did you crank the t-bars? Measure from the center of the hub nut to the bottom of the fender. You wanna be around 23.5". Higher than that can cause excess stress on the front suspension/steering.
IISPEEDYII
Pennsylvania
Same I have a double din touch screen radio. Couldn't be happier with the sound output compared to the stock radio. The subwoofer hits even harder.
Bananatank
Hammond,la
I will check soon. I don't think im higher than 23.5. Does anyone have any guess on what that could be on the roof. It appears to be after market but idk.
Bananatank
Hammond,la
How much was it do you remember?I've been looking for a good touch screen radio.
IISPEEDYII
Pennsylvania
Well when I bought it it was 900 because it's a touch and nav but that was like 2 years ago. If you want just the radio without the nav there are much cheaper options, mine is a JVC, it worked really well with my iPhone I have to say compared to other radios my friends have
Bananatank
Hammond,la
Really just looking for a good radio probably looking for a touch screen just want it to to be able to have back up camera and aux port and bluetooth
IISPEEDYII
Pennsylvania
No it's not. That's sorta like what I had to have put on mine though, it probably is the gps antenna. At least that's what mine is, again it had to be put on cause I have the nav radio installed.
Bananatank
Hammond,la
So this is aftermarket?
