H3 2006 temperature problem
bull5
Switzerland
Hi
I have an issue with my h3. The temp. gauge is constantly beetween 1/4 and 1/2. Last year the read was between 1/2 and 3/4.
In motorway the temp is constantly 1/4. Do you have an idea avoit what it can be the cause? Thanks for your inputs.
Acer4LO
Illinois
Most likely is the coolant temperature sensor
Funny you should say that. I just made a video on how to fix that for the Alpha only, but the same principal will apply for the I5. Just a different location of where the sensor is I am guessing. Now Bull5 I cannot guarantee that is the problem, but to give you an idea how to fix it you can check out my video:
[video=youtube;178MOqNLaxk]https://www.youtube.com/watch?v=178MOqNLaxk[/video]
bull5
Switzerland
Hi
Thx for the reply.
have no p code. It can not be the thermostat? The temperature gauge is moving. Just when I'm driving in a motorway that the temperature is going down till 1/4.
Gunner_45
Texas
Mine is doing that. T-stat seems to be stuck open. Scan gauge says temp is 168/172 and that is as warm as it gets.
Check the upper radiator hose after a cold start. If it is warming up or there is pressure then the tstat is stuck open. Usually it should pressure up around the tstat opening point (180-190*).
If it takes too long to warm up then thats another indicator of an open tstat. Also very low highway temps
bull5
Switzerland
Thanks, looks like the damn thermostat! I will order one.
