Low Profile Ball Joint Zerks (Homemade)
This is what happens when ya have too much time to waste!! :)
Ok, there are probably some low profile zerks avail for 59 cents somewhere, but I couldn't find any ...so I made a couple that'll keep a comfortable gap between the joint and the axle boot.
Cheers
Traxx
PNW
If you get the correct ball joints with the zerk in the right spot it saves alot of frustration.
I was worried about mine as well, I used the same ones you did. In the end I found there wasn't an issue with clearance, but you do need to make sure to get the fitting pointing the right direction. I found it best to put the zerk on first, then install the ball joint so that I could make sure it was pointing the right direction.
