H3 Oil light
samiamakasamuel
Kershaw
I have a 06 Hummer h3 when I’m driving it and stop at a light or park the rpms drop enough to cause the oil light to come on. What do I need to check.
mjferencak
Elbert, CO
Check your oil level first. Your oil sensor could be bad. Worst case scenario your oil pump is going out.
You will need to Remove entire engine to do that (I did)
Before you do that try the following steps,
1. Check oil level
2. Replace oil and filter and new sensor at the same time. Do an engine flush too
3. If it comes back, try seafoam
If all didnt work, engine out.
I tryed step 1 and 2, repeated step 2 three times. After the engine was out and opened, it turned out that an Oil bypass valve was stuck open causing low oil pressure when hot. It had alot of sludge and only needed cleaning.
Pull the plug off the sending unit. If it's bad, you'll see oil. First indication on mine was a frantic phone call from my wife screaming the oil light is on while on 465 in Indianapolis.
mjferencak
Elbert, CO
There are various concoction to an engine flush. It involves pouring a concoction in with the oil and running the engine for a few minutes or miles and draining the oil mixture. Some people use seafoam, some use mystery oil, some even use diesel and kerosene.
Does it continue to idle low for a long duration when you stop or is it a momentary drop then climbs back up? If it is momentary then clean your MAF and check your spark plugs, they may be fouled and need to be replaced. All very easy to do.
Mass Air Flow sensor, it's the sensor that is screwed onto the inlet pipe just next to the air box.
Get a can of electronics cleaner at Walmart or AutoZone or something, remove the screws holding the sensor in place, pull it out and blast it really well with the cleaner, then put it back.
