Regular maintenance milestones
K0PIR
Pierre, SD
Check your manual for more info, but basically at 50,000 inspect or replace your air filter, change automatic transmission fluid and filter, change transfer case fluid. Yours may be different than mine, depending on driving conditions and model.
I visually inspect for leaks, tears in boots and anything out of the ordinary (noises) on a regular basis. The front end is my concern. I changed my diff fluid at 30,000 miles. I changed my transfer case fluid more often than the manual says too, at 30,000 miles and I'll change my auto transmission fluid before 50,000 miles.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Since you're in the mid-west I would do what my uncles in MN do. Any bolt you MAY need to loosen in the next 10 years, do it now and spray WD-40 on everything.
I think they are right on target - diff, transfer case and transmission fluids.
Sent from my SM-P905V using Tapatalk
S
SedonaBound
If its an 06/07, its pushing 9-10 yrs old and you may want to think about age as well as mileage; brake fluid, coolant, belts, hoses.
derian06
Red Rockett
Madison, AL
Im going to hit 100,000 miles pretty soon and this is what I was going to do,
Oil change
Transmission fluid change
Both diffs fluid change
Transfer case fluid change
Change breaks
Change spark plugs
Anything else?
Clwnshu99
Abingdon, MD
Im right behind you derian, that was my plan as well, I may do it today since Im going camping 4.5 hours away friday.
K0PIR
Pierre, SD
MAF and throttle body cleaning. Mine gets done about every 10,000 miles.
