ABNTROOP
HIPPO
- Vancouver, Wa
Looks too tight for action packers. What about some RPG ammo cans?
lol... that was kind of the point - you could use the fingers on one hand to count the number of times in the last year that I replaced stock for stock....
in seriousness, though, sometimes stock parts are better - though in pricing the stock-replacement cats I found that they're in the $500 range. The better option is buy a 2008 Avalanche two-piece system, add post-cat O2 sensors and install that. The benefit of that is I don't end up with 2 cats per side - because the 2nd cats are not monitored they can be eliminated (not legally, mind you) but it would still pass smog checks because they check the computer for error codes.
I did learn something interesting, though. the 2nd O2 sensors don't stay on all the time. They require that the car maintain 2500 rpm for 6 minutes and either put the car in drive or be driving 6 minutes at 2500 rpm to get the test system to enable. That means that if you have problems passing smog, you can clear codes, drive the car around town for a couple weeks to get a history and it would pass.... even though the cats aren't, actually, working. And before someone says it, that's actually the opposite of what VW did...
more likely I'm going to buy a box of stainless u-bends, 2 cats, (I think I still have a box of o2 sensor bungs) and fab up my own cat system. The benefit being higher flow. Should I do that, I probably will modify or simply build a new cat back system because I think the borla one is kind of silly with 2 resonators and a huge muffler.... and if I don't like the sound, I'll simply put it back on.
Removing the second cat won't throw any codes. That may or may not be talking from experience.
