I gotta agree with BCIL on the drivers-side bushing assessment. You can't clamp one end of the rack rigidly to the frame...and leave soft bushings in the other end. It will eventually push itself apart. We've all seen this. The rack casting breaks right where the sheet metal tube portion gets pressed-on to it...and it starts to separate as you continue to use it. Eventually, it will separate to the point (1/4" to 1/2") where the rigid PS fluid tube cracks and pukes the entire system out on the trail. Its important to note that this separation is not from external forces...its from the tremendous hydraulic pressure inside the rack. The separation occurs because the drivers-side (the casting) is bolted to the frame...and the passenger-side (the steel tube) clamp is worn-out and loose. Internal pressure is what pushes the two pieces apart, and movement between the two mounting points is what allows it to crack in the first place.
What all of these guys are doing with the passenger-side clamp is great...and it needs to be done. However, they are basically reversing the same scenario by leaving the rubber bushings in place on the drivers-side. Now, instead of a sloppy p.s. clamp and firm d.s. bushings....you'll have a solid p.s. clamp, and sloppy d.s. bushings. A flemsy assembly needs to be allowed to either move together...or not move together. Rigidly attaching only one mounting point of such an assembly, is not an option. The two mounting points need to be addressed together...either leave them all bushed...or make them all solid. That's not rocket science...its just basic engineering.
You have an identical situation going on with the front axle bushings. It does no good to replace just the lower crossmember bushing, and leave the soft sloppy ones on the outboard mounts. The three bushings work together, and you need to make them all soft...or all firm. Otherwise, you're allowing a relatively flexible assembly (the axle housing in this case) to be pried and pulled apart from the inside forces. Just like the rack...movement between the three mounting points is what lets the axle push & pry itself apart. Outfitter Design understands this, and I think their axle bushing kit is the single biggest improvement you can make to the stock IFS. Period. (And no, I didn't get paid to say that).
On the rack issue...all of these guys are doing the same thing with the passenger-side clamp, so I don't even see enough difference to debate it. But, I'm all for the guy that includes solid d.s. bushings in his steering kit, because they need to be there. Unfortunately, I'm so confused from the numerous comparisons on this thread I can't tell which guy (or manufacturer) actually provides them.
So who includes the drivers-side bushings? That's where I'm sending my money.
