adventr
- United States
For the Transmission Temps in Torque, you can just load the GM Extended PIDs. There's no need to manually type in the PID - I think loading the extended PIDs is under a menu setting lower down in the list of settings (sorry, it's been a few years since I did this). There is Transmission Temp 1 & 2 - one of them work with the H3, just load it and if it shows temperature, you know you are on the right PID
For Oil, the H3 doesn't have an Oil Pressure or Temperature PID (that I've been able to find). If anyone knows the PID, post it here!
The extended PIDs for trans temp didn't work on my H3, and I've read where they didn't work on other's as well. That's why I created this thread, as I was unable to find where anyone had gotten the trans temp to work on the Alphas.
Also, Oil Pressure and Oil Temp under the extended PIDs work just fine on my rig:
