Clips on both the front drive shaft and the rear drive shaft. Never seen u-joints held in with resin before. Front driveshaft uses c-clips inside the ears, rear driveshaft as the outer clips.
Thanks! Good to know.
Resin bonding was something GM used to do. Not sure when they got away from it (90's?? ..ha, ha). It sure held them in tight. Clips are easier to work with. Vehicle was at the shop so I couldn't look at.
