- WI
Need lower Ball Joints. What have you guys used with good luck?
I was planning on ordering GM replacements but the pictures I saw those don't have the retaining clip on the bottom. Maybe it's not needed (??). What have you found? I really don't do any wheeling. I know the knee-jerk response is to say, "you GOTTA HAVE grease zerks!" but honestly, I'm not sure anymore. I've changed a decent number of ball joints over 25 years ..always do comprehensive maintenance to my vehicles, ...I seem to have gotten as many or more miles out on non-greasable *OEM Quality* ball joints, if not more.
I would 'suspect' that the GM replacements would be the right hardness and should contain an inner hardened cage around the ball, that extends ball joint life (which a lot of the cheapie joints don't have). I'm more concerned with good quality in the first place, than a zerk. I also see GM sells a less expensive kit WITH a zerk ...I think I saw a Moog with one too (not the problem-solver though). The problem with most ball joints is eventually the boot fills with grease (even if ya only grease a little at a time) and can tear. Not many ball joint boots have a grease-relief-hole ....like I've seen on a few, which is a great idea to keep water out, but let old grease out too. Anyone know what joint might have that?
Soooo..... all that being said, what have you found?
Big thanks for your replies!!
