2007 H3 I5 Build
zackcrum
Corinth MS
Do you have q direct hot and ground with the proper gauge wire running from the battery to the amp? Do you have rca cables running from the radio to the amp? Check the fuses in the amp itself to see if they are good. You can run your remote wire to a hot wire and see if that allows your amp to turn off if you've done all the other things correctly ans the amp power signal wire still doesn't turn it on.
poweraidon
georgia
Check that you have a good ground... When I installed mine it was a pain to fine a good ground and my subs didn't didn't turn on cause of that
derian06
Red Rockett
Madison, AL
everything worked out properly, I just blew the fuses in my amp too. 2$ and everything is working great! I grounded it in-between the two back seats, had to use a tire iron to un bolt the bolt that keeps the seats in place.
derian06
Red Rockett
Madison, AL
I also noticed that with the 315's I still have alot of space between my tires and my wheel wells. It looks like alot more then normal. Is it just my eyes or could something actually cause that?
Bananatank
Hammond,la
I see it as well looks like you have more room than usual with 315's. Idk might just b me tho maybe a 1' body lift is on it
derian06
Red Rockett
Madison, AL
How much plastidip did you use on the fenders?
Like how many cans and coats?
I am thinking about plasti dipping some things as well!
Honestly if I could do it again I would use bedliner, plasti-dip peels. You'll get little dots of your cars color whenever you try to take off mud/bugs. But I sprayed 8 coats so i'm guessing a can for each maybe? If you're looking for something short term and remove able its great. But be sure when you're spraying it on larger surfaces you always do a 1/2 overlapping spray pr you will end up with streaks that are visible in the sunlight.
derian06
Red Rockett
Madison, AL
derian06
Red Rockett
Madison, AL
I have enough money to buy my 50" light bar and mount, but I have no idea how to wire it. Can someone give me a detailed description on how to wire it and what to buy with links?
benlaud87
Maryland
I would think that it would come with a wiring harness but if not, just some wire and a switch is all you need
