zackcrum
- Corinth MS
Do you have q direct hot and ground with the proper gauge wire running from the battery to the amp? Do you have rca cables running from the radio to the amp? Check the fuses in the amp itself to see if they are good. You can run your remote wire to a hot wire and see if that allows your amp to turn off if you've done all the other things correctly ans the amp power signal wire still doesn't turn it on.
