- Meridian, ID
a link to the catch can torres?
man you got me thinking I should do this too. Did some reading up on it last night and they said this is important to add to boosted rigs..... for $20 I guess it's worth a shot!
Get rid of the stock connector(where the hard line connects to the rubber line). Mine were leaking and from what I read, it's a common failure point. I know there is a thread somewhere on it.
Well got back yesterday from training and first thing today. I installed my transmission cooler and fully by passed it. Took me about 3 hours most of it was trying to figure out how and where to set the cooler. Here it is I feel up the transmission cooler as to try an get as much air as possible as well to know exactly how much additions fluids the truck is going to need over stock quantity. The cooler took a good 3/4 of a quart of transmission oil. You smart folks do the math.
I'm running he same transmission cooler as our admin Alrock. As well bass my set up close to what he had. However I decide to leave the old radiator transmission pipes just in case. ( all I'll need is 2 short pieces of hoses). As i I plugged them poorly right now but I plan to plug them properly tomorrow. I pretty much used everything that the kit came with.
Now all it's left is a the oil change which is being drain as I type. As I expected the oil cash can is dry but it was installed a little late from the last oil change. After this one I'll report if It catches any, and if so how much.
Torres
the trans cooler is something I'm seriously considering doing. Summer is starting here as far as the heat even though it's spring still. In The gridlock drive home today I just watched the needle rise to halfway as we approached 90 on my rear view temp thingy. Believe it or not I knew something was wrong last year when it said like 104 and I knew it wasn't 104 outside..turned out my fan clutch was shot and the car heat made the rear view temp monitor rise up. Anywho as I sat today and watched the needle and the rear view temp rise I could only imagine how hot the tranny fluid was. This bypass makes sense for that and to avoid the dreaded radiator coolant leak into tranny issue. What do you use to monitor the tranny temp and any other such important data from within the vehicle. Thanks in advance
True that, thanks. I have read here that the newer thermostats changed the temp and have the 3's running at half for normal operating temp. I stay at 1/4 except for times like meow with this gridlock and nasty heat the needle gos up. I have to hit up the junk yards to search for a replacement thermostat to hoard or if we could find one to use that doesn't put us at 1/2 I'd be down. Heck I'd even consider running without one but not sure that's a good idea.
If the old rad broke and mixed some fluids and you got it fixed under warranty consider yourself a very lucky man lol...I.m At 106k now and the clock is a ticking hehehe. Got to do something like radiator or cooler bypass asap perhaps. Thanks for the info I'll keep posted to see whatsup and likewise let you know if I come across anything.
Yea I didnt see any record of radioator replacement or tranny fluid change when I got it with about 60k. :gaah: I'm iffy on doing a tranny flush at this point if it's never been done before.
Just bumped an interesting thread I found.
http://www.hummer4x4offroad.com/for...sion-Temp&highlight=Monitor+transmission+temp
I really really need to change my xfer case fluid, I never have and it's probably the original fluid from 05, I'm scared to see what it looks like.
Does this mean you will be going to Last Chance Canyon with us?
