H3 hid xenon conversation kit
marko.kessler
Good day, I purchased a kit to replace my existing h13 headlamps. I thought I got a bad unit originally... Then another, then another. Friend of mine told me that I likely need canbus ballasts for gm.
Is this true.... Does h3 need canbus ballasts?
Thank you
Sent from my SM-N910W8 using Tapatalk
Nope. Are you using a relay for the head lights? If not then you should.
Not for HID's, they need to be in a projector housing that has the ability to adjust the cutoff plate to switch between "low" (cutoff beam) and "high" (no beam cutoff). If you're still using the factory housings, then you need to be smacked with a rotting fish as they are NOT designed to focus the beam pattern from an HID bulb, only from the halogen bulb it was designed for. The HID will just scatter light everywhere in a factory housing, blinding everyone around you and making you the target of death threats. I severely despise anyone that thinks it's OK to put HID's in halogen headlight housings, more than Woodtick hates chrome.
Are you sure the bulbs you have are HI/LO?
Also the relay could be faulty
boe
Germany
There are HID conversion kits pretending to be able of HI/LO but they are complete crap! Not the slightest improvement of light just blinding everyone else.
Only way for fitting HID properly is using projector housings with HI/LO ability as JPaul said.
I know what I'm talking about because the former owner of my H3 installed this Hi/LO-HID crap. When I realized it (first night drive) I threw them out and replaced them with normal ones (Philips Vision Extreme). Instantly much better light.
I used the projector solution for some years in my motorcycle and was absolutely happy wiht it. Great light and not blinding anyone.
I used to run HIDs on the 06 H3, glared some people but not most since most ppl here have SUVS and the majority of the ppl who complained where the sedans(I was running 55W retrofits). The difference in lighting was huge but removed them eventually when LED light bars became much more affordable and I no longer needed strong headlights for offroad.
derian06
Red Rockett
Madison, AL
Make sure its a bi xenon bulb and relay, I ran some 55w 5000k before I switched to projectors. The high/lo worked fine. Should be a dual filament bulb.
