Rough Country Level Kit and Front Bump Stops
cory9oh4
Florida
H3's don't require any kit to level them. Just crank up the bars so the front fenders are 23.5" from the hub centerline, and get it aligned.
Longer shocks or extensions are a good idea. Extended bump-stops will help control nose-dive, which some drivers find to be a problem.
cory9oh4
Florida
Dang... Just spent $60 for nothing... Should I still get an alignment after I install the level kit? It brings it up 2.5" front and 0.5" rear
Pappibri
Cohoctah, MI
If you do, go to Firestone and get their lifetime alignment. Usually can find a coupon online. If you wheel, or do your own front end work it will pay for itself
Vdawg1115
Oakland, CA
I am running this kit on mine. True, you don't need it to lift the front but if you have it just do it. I don't run the extended bump stops and I don't mind. I do feel the nose dive but I heard the bump stops make it ride rough.
Hopkins86
Loogootee,IN
What is the wheel patter on the 2006 h3 I'm also trying to fig out what back spacing and other suff do I need when installing the ranco 4inch front and 3 inch rear lift kit on my h3 I'm trying to fig out some rims that will work with that set up
Ben
Winnipeg
I'm using stock rims with Motorsport 1.75 inch wheel spacer
Bolt pattern is 6 on 5-1/2" (or 6 on 139.7mm). I have run 35"x12.50" and also 37"x13.50"...both BFG Mud Terrain KM2s.
