Interesting, here in the U.S its the smaller the percentage the darker the tint, so 5% is full black, and then 100% would be clear.Yes, I have 20% upfront and 30% everywhere else
(In this country 100% would be full black)
yea i have to say the vision is really cut down with 20% on the windshield, im thinking about replacing it with a special mirror tint that you cant see in during the day but at night its clear as can be for wheeling and stuff.Front windshield used to be (30%)
At night no one would be visible inside the car if you look from the outside.
But after replacing the front windshield for the second time I went with 20% because with the old (30%) setup I cant see clearly when driving in dark alleys and it really affected long distance vision when out offroad in the desert at night.
You say that now until you do it, doesn't give the black look as a true 20% film
That was a mirrored film I had on for a few weeks
Yeah, it really sucks. Real lack of R&D on wind displacement.
well idc about the black look, i care more about not being able to see any occupants inside. lol
great intimidation factor not being able to see inThat is true haha
FWIW, I've never heard of the vibration issues with the G2 brackets, maybe they are thicker? Although I don't know if they are available anymore.
I used only self-tapping screws on my G2 brackets...no vibration at all at any speed.Those that are complaining about vibration, did you use self tapping screws or rivnuts? I only use rivnuts on installs that I personally do, and no vibration at 70+ mph down the road, wind noise obviously but no vibration.
Adding stiffeners to the brackets isn't a great idea, with the wide variance in manufacturer light bar length and tolerances you'll fatigue the hell out of the a pillar sheetmetal if the bracket can't "give" some.
I recently mounted mine on the upper windshield. No unexpectedly bad wind noise until I reach 70-80 Mph at which point it starts to whistle. If I'm headed into a headwind at those speeds, it is deafening. We recently had a large snow storm that covered the gap on top and the wind noise disappeared. It seems the wind is kicking up off the windshield causing the whistle. I plan on building a Gobi Stealth style roof rack and I may bring the front deflector to just over the light with a panel that closes the top gap of the light bar. I have also heard of people putting door edging along some of the cooling fins to help with this. I may give that a shot.
View attachment 21905View attachment 21904
turn your bar over... I had the same issue, did the same fix, then someone pointed out they are different top/bottom... flipped it over. Noise is gone.Minimal wind noise after adding door trim to bottom half of cooling fins off the light bar.
My cooling fins are the same top and bottom but I have the vapor breather that needs to stay on top to keep from getting moisture build up.
