H3T Sure doesn't look like 35s fit...
FactoryOrdered2010AlphaT
Canada
why not just have them mount wheels that fit properly?
I blame Custom Offsets for their propaganda on 'stance' for that.
After nine years I wanted to shake things up a bit - looked at hundreds of styles - couldn't find one with seven spokes in silver/chrome/machined - got hooked on Nitto Ridge Grapplers and that was the end of looking for 16s: they only have 265 or 285 in that size.
Wanted a more 3D style without sacrificing too much sidewall - these were the best I could find (that I liked) quickly - when we found out they only had a +15 offset...that we might have to move them out a bit...well that brain washing kicked in: "stance".
They're also 'temporary' in the sense they won't last more than two or three seasons with the sort of salt-bath they get subjected to up here.
Traxx
PNW
Temporary might be a good term to describe the wheel bearings, half shafts, steering rack, and ball joints too with the added stress. :) Hopefully you used a high quality wheel spacer on a near 3 ton vehicle, lot of shear stress on those lugs.
Canada
6061-T6 Aluminum, I believe, from the same Canadian manufacturer as the wheels, Fast co, (branding accessories as Dailyn since 2018) 77339 Thickness: 1.50"/38mm Center Bore: 108.0 Vehicle: 6x139.7 Wheel: 6/139.7mm Thread 12x1.50mm
Canada
Let me insert my thanks to hummer4x4offroad.com for being right here, hub for a vibrant community with a history of sharing. Shared knowledge moves us forward and we owe these modern librarians for what they do. Here's a little gift for those seeking deep knowledge. You can ask google to search the knowledge of this site by entering this into a Google.com search (or the Chrome search bar): site:www.hummer4x4offroad.com t-bar
replace t-bar with the knowledge you seek.
Now... without further delay (it's only been 9 years...) let's see some H3T tire porn!
Gunner_45
Texas
That does not look much worse than mine.
Been running that way since I bought the rig in 2010.
However, I did have to replace the front bearings a couple of years ago IRC.
Canada
does not look much worse than mine. Been running that way since I bought the rig in 2010. However, I did have to replace the front bearings a couple of years ago IRC.
Wasn't surprised I needed to replace bearings around 136k miles. Could feel them getting incrementally worse. They put up with 33" Duelers for 8.5 years and a fair amount of aggressive driving...I felt bad for them! Front first, rears within a month. Just googled general life expectancy now:
"An average sealed wheel bearing lasts 85,000 to 100,000 miles although some can last as long as 150,000 miles."
Wasn't unhappy with what I got out of them - could certainly tell they were replaced.
You didn't need spacers for those Pro Comp's did you?
