- Tardville
2006 H3 AT trans...160k miles. Key gets stuck in the ignition tumbler...but starts fine. I can shut the motor off but, I cannot shut the power off. The key will not turn back to "lock" and will not come out of the tumbler. So the ACC is on and the radio, fan, and such are all stuck on. I must take the cowling off the column and remove the passlock solenoid from them tumbler, and then I can turn the key back to lock and pull it out. Good battery. Good voltage.
Here's the weird thing. The shifter can be put into any gear at any time...with the vehicle running or not...with the key in it or not. It can also be pulled in or out of Park without touching the brake pedal. Its like the shifter is not even connected to the ignition system. Passlock light is on but, starts fine. Anybody ever had shifter issues? I'm stumped.
