BW_Hummer H3
- Texas
So how more flex will this add? Also I like the duct tape on your boot.
Then I need longer brakelines and need to flex out the suspension tool
Thanks Rick. you think 5in over stock is good?
I will probably go with high angle driveline Mike, like you said it is very thin walled. 4speed was getting his rear driveshaft lengthened and IIRC the driveline guy was shocked at how thin it was. As for the front driveshaft I am running a double cardian shaft that I bought through 4speedfunk. He had a few made for rancho guys. supposedly the problem wasnt the stock shaft itself but it was the boot. Here is gets rid of the boot and it has a few zerk fittings that you give a few pumps of grease every oil change or before a long offroading weekend and your good to go. I havent had any issues with it yet, its very stout and 4speed was telling me the most common way of destroying them is neglect and letting the grease run dry but even then the rebuild kits are cheap.
Here is a pic of the stock one next to the new front one. The new one looks a tad longer but it is just adjustable in length with the slip joint. After this I will be running custom front and rear shafts...Damn I am start to feel like a frankenstein!
I know some had concerns with weld strength and I plan to address this issue. First I will go to a local shop and have them examine the welds, I already had an experienced welder look into it and said the penetration was there but will also check into a shop looking at them. Then I will do a few local runs and try and beat the **** out of it. If no welds break I will do the ultimate test :huh::emb:
Jump it! lol I know it sounds ridiculously stupid but I wanna beat the **** out of it locally and make sure everything holds up.
