derian06
Red Rockett
- Madison, AL
I'm getting around 200 to the tank right now, thats a significant difference!
I've gotten real spoiled the last 40k miles being able to do this
This has me digging into the PCS 2650 to run this as a standalone. This may be a viable option now that the hard parts are worked out. (Not hard difficult, I mean the shafts, adapters). I'd love to get that short gap double overdrive behind the diesel.
That looks nice! Sounds a lot more liniar than when I stomp on it... if you listen behind the wine of the S/C of course!Here's a quick highway acceleration video.
No lag in the downshifts! It just gets up and goes.
https://youtu.be/xG8AjtMdj4Q
:thumbs:
dang dude, my speedometer has never seen north of 70 hahahahah. i5 probs
Please adventr, can you make a video showing 0 to 60 times? At 100% throttle if you can..the comparison between the 4L60e and the 6L80e acceleration under wot would be great.
i believe the 08 and up like i have has a combinded pcm/tcm controller.If your vehicle has a TCM, then yes this is all is needed plus a torque converter.
Offcourse the trans needs to come from an AWD 2007/2008/2009 and maybe up to 2011 since the valve body of the 6l80e was revised sometime during that period.
What if you have the 06'??? What items are needed?If your vehicle has a TCM, then yes this is all is needed plus a torque converter.
Great idea... I might be that guy depending on how this fuel pump issue get sorted outI have an output shaft that will be here any day now and will be sending that off to get resplined. Once I have it swapped, I will have a core output shaft to send to the next swapper to get resplined.
The 6l80e wasn't adapted to an I5.
