FJ4overland
Part of tonight was getting doors
worth $380? probably not, but I'm simply going to spray them - they're for winter use only and they really simply need to match... maybe next summer I'll give them a once over but more likely I won't
and I got the other skin welded up.
Today was kind of full between an auto parts swap, deck work, and inevitable honey-dos
But I got more done.
got the paint off the outside of the doors
rubber was removed
rusted bolts removed
also finished my jumper cable mods
accidently, while taking the rubber off with a wire-wheel, I found that it does an amazing job of removing Rustoleum
also did a bit of welding
My goal is finish all the doors this week then paint them and the roof frame this weekend. I was going to powder coat, but by the time I get the coating done I don't think I'll make my 'roof by the 29th' goal (and wheeling in the snow and mud without a roof is a great way to put hair on your chest.... I already have hair on my chest)
I hate bodywork.... alas, first an instructional on taking a window regulator out of a pre-77 FJ40
take 4 screws out of regulator, run window to bottom, rotate entire regulator assembly towards front of door, remove
weld up some holes
oh wait, bubba got to fitting the door
bubba was also a large boy and broke the door stop
while my name isn't MP&C, I can fix this
bend up a similar piece on the brake
and fit
then weld
hmmmm... my camera takes most of the pictures, apparently it was quitting time when I took the last one of it finished from the front... ah well, tomorrow night
More door work
it doesn't fit
even with adjusting
other door fits great :)
now driver's door fits good... just took a bit of bending
and since I was already bending... I put these doors together for the final time
It was a blast today
Other then continually having to unwedge Buick from my seat
pretty, it is
It worked pretty well, not ready to claim it's reliable
and got clearer as the day progressed
with a bit of time to play in the mud
so the list to fix is actually pretty benign and short.
1) remove the driver's side header and fix a leak
2) fix a couple wiring issues (one headlight and a marker aren't working all the time)
3) get the front stabilizer on and maybe lower the panhard bar mount
4) fix the linkage for rear 4 lo - I didn't have low today because it wouldn't come out of high... I'm thinking I simply need to give up on this mechanism and try a different one
5) put a doggie block to keep Buick in the back.... he was a pain today
6) I'm going to change the thermostat again.... today, it was either 220* or 180*.... to me that's a faulty thermostat or the computer is bouncing between it thinking it's cold and richening the mixture (which is either a sensor or a computer)... so I'll change one at a time but see if I can't solve that
7) I need to raise the back at least 1 1/2"
In other news, the power steering cooler worked great and solved the whining issue
the water pump pulley fixed the squeak
there was only the occasional leak around the edges - and it was raining pretty steadily.
and in random news. the truck, loaded weighs 5060
Interesting.... Four Wheel and Offroad "reader's rides bonanza" page 22 Feb 2017. I'm kind of surprised, given the hate I've given them about being Jeep only - of course, had I sent pictures of the Hummer; that would have guaranteed an ignore.
You might try a vacuum purge on the coolant system. Sudden wild fluctuations in coolant temp are probably air pockets flowing past the temp sensor. Have you noticed the cabin heat mysteriously coming and going?
it's a valid thing to look at, but it doesn't bounce - it stays 180 then slowly climbs up to 220 then slowly comes down to 180 - sometimes at highway speeds, sometimes just because. Truly like the thermostat can't make up its mind - I wonder if they make male thermostats? It also runs different at 220 - which, to me at least, seems to confirm it's not just a gauge issue. I did make a mistake on plumbing it but even that mistake wouldn't cause the issue (it's got pressure to both sides of the core). On top of all of this, inlet temps stays steady at 159.
It needed camber set - so it's at a friend's shop, he also will look at the issue... another clue to all of this is this. When I reset the timing to 15* base timing (as opposed to the GM spec'd 0), that actually really helped the issue.... red herring? a clue? dunno...
not really a huge deal because all it took was submitting - granted I sent in awhile before, I find it interesting they used pretty much my entire writing without edit.
Headers, ugh!
I 'saved' myself time and effort by buying what I thought was 18 ga stainless headers. They might be stainless, but I'm thinking they're chinesium... before anyone gets on my case about these silicone welds, this is to simply to reduce leakage until I can build new ones.... but since there's a deck, a trailer, a RV trailer before I have that kind of time to invest...
I flattened these last time I did this
you can see where they're leaking - that rust color comes from the exhaust leak
I do like Percy's gaskets - these are reuseable... and reused
silicone weld time
blowing lots of holes because they're maybe 20 ga.
and more rust repair coming... but first
doors
a bit more work
knocked it down
premature primer, but for a reason .... it's getting too cold to work on these so it's time to prime them and stick them into the rafters then pull them down when Spring springs
so it's time to finish the roof install.... was waiting for instructions, but got tired of waiting - which means it could be wrong, but it's not.
screw in the twisties
then take a deep breath and cut a hole in your brand-new, $1,500 top
and put the ring on
that was the first one... next round went a bit easier
mark the heads
then trim a bunch and install
finally a better plan... mark the heads as above, then use the backing ring to mark how much material to cut out
like so
by now, cutting holes is easy
punch 4 holes for the tabs
and hammer over using a block of wood as a dolly behind the mount.... easy, no?
so more detail work, these are late 90s F350 van front springs - right diameter, increased wire size, and progressive...
fixing the land cruiser lean by unequal cuts to bring it down to the right length
I need to tune this a bit more... but it's close, very close
but then I got interrupted by my wife's Heep - she filled her inverter and a plug full of water... electric devices don't like water (who knew?)
but we're back
so I added a 2" spacer for a bit of insulation from noise and put it back together... now I have 5" travel (middle of the travel) for the rear and the rig is dead level front/back
for those counting, it was 24" with 31" tires to the bottom of the rocker panel. Now it's 28 with 38.5s and a whole bunch more travel. It's ready for 40s, my wallet isn't ready for them, but finally....
so back on the ground it had a land cruiser lean, but the other way... equalized the front coil overs, still no joy.... so time to make both rear springs level
as you can see by the picture, the first strap just could hold the axle twice so time to do something a bit more creative
and install the bump stop too
no more lean.
and it drives excellent. I still need to reset the castor (again) because along with an issue with the driveshaft angle, they changed the castor to the point where it's darty... no big deal, just a quick adjustment
So as you know, I went wheeling yesterday.... beside not taking enough air pressure out (18 vs. 8)... things went okay. Well, okay if you consider almost rolling it at 70 mph. Pulled off the freeway and the steering box was loose, again.... on top of this, I've been really needing to tie the frame rails together since all of the force is on one rail... so that was today's work
I suppose if I was doing a full hard-core vehicle, I'd just put a mid-plate in... but I like not rattling fillings out so the solution had to be a be less caveman
first I tied the motor mounts together - but that's pretty weak considering it's only bolted in
so I added a Y member
not a lot of clearance, but my solution (if it hits, and probably if it doesn't) will be move the track bar. It's short, it's on a high-arc and now I realize I can lengthen it and put it on less of an arc which should make 100 mph less scary
*for those without a sense of humor, 100 mph is a JOKE.....
Not a lot has been happening - most of the major problems have been solved so I've been dealing with other, non-car stuff....
but first I complained about how I need to break down the sidewalls a bit... this is 3 psi
needed to add a light to the dash... which I did
and then while I was cleaning up a hole, tore the wire out of the light .... picture when I get its replacement
finally purchased a distributor wrench....
this is for my wife's jeep - which I would have worked on tonight had she not been out doing SAR stuff....
blanking Mr. gasket clamp.... chromed aluminum clamp - no wonder it wasn't holding. First it had too much material so it wouldn't clamp at all... then I ground it down and it wouldn't hold after a bit...
it is clamped now. I've solved my Staun problem (18 psi instead of 8 psi deflation) with the purchase of an ARB deflator (and I have spare needles) and I got a better hose for filling.... this weekend will be a good run
steering issue is fixed. drove it tonight at it works very well. the fix was bracing the box and the panhard bar. It still has some throttle-induced understeer but since the fix would be making the panhard parallel with the axle - and the down side of that is increased bump-steer; I'll take the lesser of two evils. Especially since the lesser only happens noticeably when accelerating from a stop sign while turning (and right is worse then left).... time to get onto the next project and work on beating this thing like it owes me money.
what a glorious day - got cut short because the alternator stopped working, but still.... it was a point and shoot day in the snow (meaning wherever I wanted to go.. no problem)
normally speaking, there's a frost line on the hills - not this time, so there wasn't the slog through the cascade cement...
got a little snow up its nose
then air up
then breakfast at the cafe - an all-you-can-eat.... I like all you can eat :)
