Schwarttzy
- Rockford IL
Awesome product Schwarttzy. Love them. Thanks Humman, your video served as a great guide to putting these on.
Thanks man, glad you like it. Just promise to get them dirty for me!
So I got these as a Christmas gift from my parents, and went to install them yesterday. Ran into an issue with the supplied ubolts. They are to narrow at the top of the U to properly fit over the axle. I attempted bend it slightly which didn't work, because then it would not fit the mounting holes in the mount? Has anyone else had this issue?
Mine is an 09 T Alpha and as I mentioned the boosts are not wide enough. I will be pulling the stock Ubolt and taking measurements. Then will have a company make the correct sized ones.
I'd like to get some information on that.
56 ft lbs? Try 156 ft lbs.
56 is "finger tight" for a u-bolt. I use a breaker bar with a cheater on mine.
The H3 10-bolt uses an odd-ball size tube. But Ruffstuff has the correct size u-bolts. Ask for the "14-bolt simple swap u-bolts"...they fit perfectly. And CRANK EM as tight as you can get them.
The bolts are clearly bent inward.
I just tried installing the set that I bought a while ago and after taking a looking at the spacing of the supplied Ubolts I decided to stop and check on here first, to me it looks like the radius of the supplied bolts are too narrow for the mount bolt hole spacing, has anyone else ran into this issue or is this the way it is supposed to be? (About 1/4inch off or so)
Pic's:
