- Meridian, ID
I initially installed just the lower rear SS brake lines from crown performance but got all of em in now so I would like to document it.
I think the lower lines at the axle are perfect length. I ordered them 2in longer then stock
I think the fronts are perfect too. The rancho kit requires you to pull the stock brakelines out of the bracket so they dont snap when at full flex. These are 1 inch longer then stock and I think they are a great length, not too long not too short. I will flex it out and make sure, if there are too short I will order longer ones.
Here is where I goofed. Ordered the rear brake lines that are above the axle 6 inches longer then stock, I also have the rancho bracket that raises the hard line bracket 2 inches, so its like 8in longer then stock. Its pretty bad so I think I will pull the 2in rancho bracket out and go back to stock bracket placement and it will probably work well.
Those brakelines dont look happy!
I installed the two on the axle and the right rear kept on having the smallest leak. I couldnt get it to stop so I brought it to the dealer, seeing I was one for two on the install I let them install the fronts and top axle ones, they couldnt get it to stop leaking either so it probably wasnt my install error. They installed a new hardline and it still leaked so they tightened it up as much as possible and luckily it stopped. So they said to keep an eye on it and if it leaks again I will have to contact crown and get a new line, maybe its defective. If I get a new one I will do that install, its not that tough.
These brakelines will shine on the steep decents.
