FJ4overland
so I had to work on my H3 today, but, as is my custom, I always do something to keep moving forward on my main project
the passenger seat, with the gas tank under it, determines the seat height of the driver's side so that was my focus tonight
narrowed the old, stock bracket
now to make mounts to solid mount it
been a couple days, next one won't be until next week.... anyway
it was the classic, start, stop
I started looking to weld the mounts on the rear axle... missing one piece, so I spent time straightening up... ugh, I need a shop maid. Didn't find the bits, but I did come up with a clever way of doing the rear springs.... no pictures because I didn't work on that tonight
so then I started working on setting up the rear end
got the gear off, then got stopped because the bearings simply didn't look right - so I ordered new ones that will be here tomorrow
the first project 2 nights ago was the seat frames.... passenger side looks good, and I started mocking up the driver's side.... I dunno, I don't like the non-similar radii. That said, I'm not buying a die or bender simply for these bends so I might have to get creative with the pie cuts. The counter-balance is no one but me will see them... and that top, flat bit... is exactly the right length
anyway, I'm going out to the wilderness to break stuff.... ttfn
so, progress?
now it's as far apart as I'm going to take it (which is good since there isn't anything left to remove)
Buick thinks the old-school sbc is a good choice
on the trailer for a trip to the sand blaster
and back to the driver's seat frame.... I still don't know what I'm going to do
this is what's kind of there now
means I have to work on the trans cover a bit more....
basically I'm thinking of simply putting a gun safe under the seat, permanently.
sandblasted frame
figured it'd be easier to weld,
and it is
working on removing brackets... oh the joy of grinding dust and a 90* shop
Are you leaving the swiss cheese holes on the inside of the frame rails? (V8 you know).
Looks great. Thats a really nice frame considering the age.
I'm welding it solid and the cage is tied directly to it - should be enough.... I know, famous last lines :)
With that said, remember that there is a 75# transfer case/ rear link brace bolted to the bottom of the frame as well. Along with that, the bit that goes over the wheel is going to be boxed as well. My biggest concern is trapped moisture. I will coat it, but if it fails (without those windows) it will be way too late to fix it by the time that failure is see.
Warm day, but got some accomplished until I ran out of wire and oxygen (was using the torch too)...
with some grinding, drilling and torch work the brackets came off
I suppose I would have given up earlier if I hadn't just had to buy a bracket - so I figure that these are totally reuseable and I did save them
and removed the shock mount
some CAD work (cardboard assisted design)
copy
test
weld
turned it over to weld the top
and ran out of wire
alrighty, more progress
first fix the seam
then the upper control arm mount
notice that everything is in compression? while I do trust my welds, I also know that it's really easy to make it doubly secure by compressing the forces
gave it a quick bend and welded it up
and my weight-loss-through-sweating is over for the night
thanks for lurking ;)
so I welded... for 2 hours.... looks EXACTLY the same
even so, it's ready to turn back over and finish the bottom side. For those who have never done this - you can warp a frame with too much heat, thus tack first, weld a bit at a time, but tack both top and bottom.... then I'll flip it back up, put the motor back in place and figure out the rest of the bracing for the front hoops.
back to welding.... some more.... with the same amount of "looks like I did something"
when I did the mock up - some (this blog is simulcast to other blogs) - they were concerned the motor mounts wouldn't be strong enough... this should give them peace and let them get back to their orca ;) *
and yet others, who normally are focused on rust,* were concerned about the shock towers.... this isn't finished, but it's a downpayment on how strong the entire structure will be
anyway, I've flipped the frame over and will continue on it tomorrow night....
*I appreciate, kidding aside, that people pay attention - while it's not often I miss something, there have been a few times where what I missed was pretty important... so really, thx for lurking.
bought some extra doors so that I can make one set half-doors
cross member now done
added a winch plate
and did buckets for the rear springs..... now a cross member and it's done... then grinding, then painting... lol done.
so more work accomplished
the optical illusion on this is pretty cool, that brace is nearly vertical
just enough clearance for steering
and then some quality time welding links
plugging away.... but I'm getting pretty close to paint, just rear shock mounts (which will be pretty easy)
I cheated in the lay out
doesn't look level, yet it is
when tacking on, don't weld the removable bit
couple extra braces in front
and a brace for the steering box
and welded links
I also got grinding done on the top of the frame.... this thing is getting a bit heavy to flip over....
Believe it or not, I'm getting close to starting the final mechanical assembly....
shock mount
drill through
I observed something interesting. I have a 3/8" B&D corded drill and my makita got too warm so I went to use the B&D... not 50% of the power of the cordless Makita... though I may have injured it drilling 4 2" holes
welded in
My corvette dolly works as a FJ40 dolly as well :)
and some green on the inside of the frame rails
I would have gone with black however there's like a month-wait... and I'll spray the frame black which will cover the green nicely. Sunday the plan is to paint most of the frame. I can't do all of it because I'm not done with the rear shocks... so I'll tape that off and paint it later... I can paint it under the vehicle, so it's really not a big deal...
anyway, shipwreck is getting there :)
well I goofed.... I read the instructions. The KBS coating that I'm using has a main coat and a top coat for stuff exposed to sunlight. Not only that but it uses its own thinner (and I'm brushing this on). So no paint this weekend (even though it'd be perfect weather for doing so since it is supposed to be 90* on Sunday). Oh well, I'll finish up the cage, etch it, and the corners so I can paint all of it at once. Maybe I'll even make the frame perfect rather than close enough...
Today's fun... etching the frame
but first, how to turn the frame over... I could drive to Portand (7 hours there and back) and borrow my dad's rotisserie or I could make one or I could hum a few bars and do something that should work
and it works
yeah, so I didn't get it perfectly balanced... oh well
so then the phosphate acid bath begins
since I plan on painting the cage at the same time... it's time to remove it
I guess I'll post pictures of the actual removal tomorrow... and of what I'm going to do with the paint on the tub (once I decide what I'm going to do - I need to remove the red because it's not adhering well enough to paint over.... but I'm loathe to strip it)
tonight... welded a couple tabs on.... ugh
finish welds I couldn't get to when it was in the vehicle
then outside for stripping
and back inside to rust
tomorrow I'll weld some braces on if I get a chance (meeting night)... I was a bit disappointed that it's welded seam tube, but by the same token, for what I do, it doesn't matter.... and with a few corner braces will be just peachy.
acid bath is one of my favorite bands!
how do you like that green stuff? I bought some but I haven't used it yet.
it works well on new steel, I'm a bit disappointed at how it did on previously-painted now-sanded sheet metal
That said, the true test will be how it does creating a key for the POR 15 to adhere to it. I painted the differential covers tonight .... after a use or two will tell if it did a good job.
back to the current headache...errr.. project
cleaned the tub
it'll flow out, they said, POR 15 lies... but at least I'll wear it off pretty quickly in the snow.... still, I wish there was an easy way of spraying POR 15
and now I have a front axle with gears in it - time to order the RCV shafts.... but, like all good things, it requires an unrelated step - my printer doesn't work so I can't print out the sheet I need... ugh
and cleaned knuckles
painted them too
and started working on the rear axle then got stopped when I couldn't find my 1 5/16 socket... always something
