FJ4overland
My goal is to have this done by the end of October.... It could happen, but it's not going to happen. Body work takes time, and I'm not going to rush it. I talked to a guy who has done body and paint for me - if you're having trouble getting them to do it your way at the start..... yeah, I'll be doing most of it myself. I may take the truck to him for final paint, but between his lack of experience with the various coatings I'm using and being certain about things I know are opinion (which are "fact" because it's easier for him to do)... why give myself the headache, I hate arguing with people more than I hate bodywork.
didn't get much done on the '40 tonight... between unsticking the bobcat for the ten billionth time, doing an oil change on the H3, fixing the remote for the winch (not sure I accomplished that)... I ran out of time
the joy of working by oneself
don't try this at home folks
obviously, from my last posts, I had to flip the tub for this round of test-fitting
and viola
to simulate action, I blur the background... and i have no idea how I managed this with my point-n-shoot camera
so there is a slight issue - this cross member should be 1/4" off the frame....
and it appears my guess was too low - actually, it wasn't - I was hoping it'd be tucked up further.... so it appears plan B is going to happen (cut and brace the body mount then run the exhaust further up)
the offending brace - the problem is that's also like a major mount for the roll cage - so it needs to be as stout as now...
I'll take lucky over good every day - I lucked out on the O2 sensor
tonight's fun (who am I kidding, I hate grinding)
make some covers and it's good to go
dang, it almost looks like I know what I'm doing with that safe
gratuitous shots
now that the body is close to its mounts... time to do the front fenders
It's looking really good, I can't wait to see it put all together!
me either :giggle:
my goal was drive it in October.... I'm getting pretty sure that isn't going to happen. Every weekend in October is gone as is all but one weekend in November. Subtract two weekends in September and I'll be lucky to have it done by April.
I think this is the most body panels I've had on the vehicle yet (and yep, will still blow it apart again)
those bits from the last pictures... I'm sure I make people dizzy because I flit from one project to another... there is, at times, method to the madness - other times, I've got a case of the don'twannas and simply do something else. The fenders... yeah, don't feel like dealing with the exhaust - so here it goes
in a lower position
I think the issue with this position is it will hit a tire at full compression
boy, I need to square up the rear axle
starting to get an idea of where - I pulled it outside to get a better perspective on where to mount the fenders
one thing I am sure, I won't be using the mounting points they designed into these fenders - the mounting holes are behind the coil-over
I swear the scaffolding takes more time then everything else
one side mostly permanent now to mirror
and mirror happened
it would be a lot easier, I suppose, if I had leveled the truck first... meh, can't get too bored doing this stuff (kidding)
tonights saga begins with hubs
dana 60 hubs
yep, front axle shaft diameter is dana 60 sized... just not dana 60 hang-down on the pumpkin
35 spline double-splined axles for the rear. I think I can safely say that these won't be what breaks
I wish Nitro Gear had engraved their logo on the ends - normally, I don't do advertising - they really have helped out on this project
the axles are cut-to-fit, so I need to trim 1/2" off and all will be well
and what took all my time tonight and will again tomorrow night
and a brace... I had to move the bracket back - it's meant to attach to where the stock fenders attach, however, that's exactly where the coil over resides... oh well, if I was afraid of fabrication I'd hang out on a 4x4 site and piss and moan about everyone else's project
and sheet metal is where I stopped
so this is funny, to me.... look at this picture again
you get bonus points if you notice the radiator isn't level... I leveled the grill as part of tonight's work, and looked at the front and said "hey, wait a minute"... oh well, I also have to move it back towards the motor (lean it back) so the hood doesn't hit it... I wish I was as good as those guys on TV, *shrugs*
So wait, which part IS level?? the radiator or the body? The body is what looks to be off camber to me compared to the background/foreground/tires..
nothing in the picture, the radiator simply goes the opposite way - what makes me laugh is the legs are the same height and my mistake was presuming the holes on the radiator (for mounting) were on the same plane.
now I have front axles too!
with splines :)
time to do the time-consuming work on the fenders...
and that's where it stopped - still need to fit the sheet metal to side #1 then onto side two
Been distracted with other things but got a few things done on this
got the sheet metal on, ish
Just a bit short on one end
the finished(ish) product
so time to see compression and such stuff
looks like this fender fits
I really need to get on bolting the spring in because it's pretty annoying to watch it roll across the floor whenever I lift up the vehicle
flex... more importantly, tire clears fender
and last thing tonight was assemble the Nitro gears custom axles....
good gravy I'm irritated.
I figured tonight I'd do a fairly easy job... a bit of work leveling the fender (that was easy).. then the "easy" job of lubing bearings, installing seals, installing the axle shafts....
so I got to here
yay, end in sight... NOT
why won't the hub go on?
on the old axle, this is how it's supposed to fit
it slides over the end to give strength to the hub
but wait, it doesn't fit over the 30 spline new hubs :ha:
new hub on right, old hub on left (both milemarker premium hubs)
they're the same... however, it's a 30 spline new shaft (same as GM dana 44s) - yet it looks like someone put the ford hubs in a box with the chevy inners.... oh good grief.
I'm not throwing the supplier under the bus yet - but they are dangerously close to getting an "avoid them at all cost" rating.
the solution to the hub issue is to get the Warn hubs that RCV recommends... they even make a billet inner that's not terribly expensive...
plugging holes
in addition to getting the front end together in a more permanent fashion, I worked on a fender
thanks for the plugs, dad
all plugged
brace goes here
cut, and coped
and welded
that's all folks... g'nite
Not sure what the issue with your lockouts is. I have ran MM and Warn units on all kinds of D44s. You have make sure the hubs (the shell part...not the lockouts), match the stub shafts. Factory stubs are 19 spline (not 30) unless you have upgraded. They come in many lengths....but they have to match the hubs.
Rig looks great BTW.
they're 30 spline and that's the issue - oh yeah, and that the company who provided the axles and the hubs didn't bother checking before they sent them out the door... what bugs me is their attitude. these are pretty new to the market, so it's understandable that there'd be teething pains. I just wish they dispense with the "it's everyone's fault but mine" crap. oh well, I think keeping u-joints instead of going with CV joints is a better option because there is less chance of water infiltration and the crap that comes with water. on the other hand is the issue that could arise with these u-joints don't have needle bearings so could easily overheat if not serviced regularly.
got more done tonight
mom-in-law is going to be here tomorrow so I've done the paper mache screw together so it doesn't look (more) like a stack of parts... I still need to weld the fenders, but it's a lot closer.
Today I played hooky from the shop and went wheeling - so not much got done... just these things got worked on
and then I leaned the radiator to mimic the tilt of the motor...
​next up is a shroud
tonight was go backward, I guess... oh well, now is the time to fix this - not be embarrassed by it later
The transfer case is leaking - I guess "blind bolt" to Jeep doesn't, actually mean, separate from the fluid.... so it was leaking out the bolt... and from that cute cast pan. So I pulled it apart
but first, a congratulations - the locking hubs fit.... a bit tight, but they work and I'm glad that saga is done.
so there is A drop on the floor... schmucking gall darn it.
and apart it comes
and then problem 2 arose.... I thought, when I put it together last time that it didn't seem the male shaft was long enough for the female hole.... I measured it, and I was right... it's just a bit too short
that's a problem, though, I need at least 1/4" but it seems the best way to do this would be to take the adapter completely apart and re-fit it. Have I mentioned there are times when it would be really nice to have a lathe (again)?
schmuckity schmuck schmuck schmuck ah well, I know people so I can do this.
in the end, I simply cut it apart and pressed it back together a bit narrower
I shouldn't show this since I don't know how to weld (heh)
commercial break... the color flat olive/brown
and finally getting to the driveshaft hoop/divot to allow full drop
now that the paint's dry
you can tell I narrowed it because it's now black ;)
and it looks like I need to take just a bit out of this cross member
this actually is a red letter moment... for the first time since I owned the vehicle there is a direct connection from the crank to the front axle
