FJ4overland
Last night I started setting up the rear gears,
measuring for shims
Sprayed the KBS today - it went on pretty well, and going to get a larger-nozzle gun was the right choice - I blew this on with a 1.8 nozzle ($16.00 at HF)
round 1 the coating
then a top coat
eventually it will end up a factory matte finish - but I almost ran out of time to spray this - KBS recommends low humidity and no rain. Tomorrow it's supposed to rain, thus killing our great 35% humidity we have today.
started today by replacing the cad plated bolts with stainless ones
then bolting it together, but this time for real
and for those who are curious how much I took out of the front axle
(driver's side)
passenger side
what the cross brace looks like when apart
and now the motor is in
bit of paint and some glue....
painted
glued the front diff cover on so I could put the steering on tomorrow, and got the hubs on, the big thing was taking the upper spring out of the coil overs to get it closer to ride-height
it seems way too light, but the 300/200 springs will probably end up being 200/150... that said, I'm not driving it like this, but rather getting the ride height set so that when I get it all together, I can weigh it and get the right springs
presents.... anyone still wonder why the steering box is still blue?
a good idea, but no, too tall
too short
okay, I don't get it, why is there so much space there?
time to start on the t-case
​of course, that was a dead stop because I printed out the directions and stored them in a safe place....
moving along
adapter off
ugly... but not rusty...
dagnabit... now that's ugly and must be replaced
if the shims hadn't been trashed, I'd have reused these... for those who count - there must be 48 of these.
.... 42 - the answer to life, the universe and everything, but not the right answer for Dana 300s... I think I found 5 of the missing 6.
if you get lucky, you don't have to pull the lower gears out
the new bits
and yes, this fought me, but I won
anyway, cleaned the case up, I'll paint it tomorrow and hopefully have the instructions so I can put the upper half back together. I'll be waiting for the intermediate shaft to arrive; but I bet that's at least a week out. Which is good, I need to re-order a seal and do a bit of cleanup on the transmission....
​ttfn.
back to the transfer case
new output shaft
bearing pressed on the other side
much short = happier driveshaft angles
still awaiting the mid-shaft replacement, but at least it's mostly together and painted now.
along with the adapter
the back to the rear end
now with spring mounts and shock mounts
I may make an executive decision and let the truck be 3" over stock height so that I don't have to cut holes in the floor for the shocks
carrying on
I think these are going to look good... dually marker lights
LED tail lights - but not sure where yet
then an O2 sensor install
and the start of the exhaust
ordered the cats and mufflers (cats aren't required, but it makes wheeling so much more enjoyable since heavy fuel in the exhaust gives me a migraine)....
then onto the body.... should have most of the running gear minus axles and, driveshafts done in the next week or so...
a bit of bouncing about tonight. I'm kind of waiting for parts (especially a seal) - so I did whatever I figured needed doing
first was weld the extensions together
I've been robbing parts from the Buick - but it makes no sense to simply sit on the parts for another 5 years
I ordered new lines and I'll have to adapt to the Scout box (7/16 fitting rather then 18 mm).... however, everything from the pump is metric so it won't be that hard to do. I also have to put another return into the power steering pump.... easy enough. I want brakes, and hydraboost will give me solid brakes - especially with 4 wheel disk brakes
adapted the pedals
then I started planning the brake lines and putting the various sensors on the motor for EFI and the electronic dash
Parts, not the right parts, but parts and I made them work
I got to see this a lot - I would have updated last night but there was no update since I got to see this again today
cleanup a bit
problem 1
that slot is in the wrong spot AND it doesn't have an o-ring - fortunately, I got to take it back apart and fix that today
adapter back in place
gear in place, if you look closely on your left, you'll see a copper colored shim...last night, after I had it all together, I spun the input and it hung up. I pulled it apart, and one shim hadn't stayed in place when I put it together.... thus, I got to see the first empty picture again today.
mufflers and cats came today
1st fitting
better fitting
now with brace
so I didn't get much done today. beside picking up the Land Rover, installing a new microwave, and installing a drain on a water container the '40 got ignored....ish
seat base
I'm going to remove the electronics and simply use a key.
but of course to install that I need to take advantage of unexpected nice weather and haul the shell to get sand blasted
and pull the transmission from the frame so I can do some finish work on the clutch, etc
pull the tailshaft off
nothing looks broken
basically I need to hone out the seal area a bit more to get a seal installed
water jug
who knew that 30 ton presses make excellent clamps too?
If you are of a sensitive nature... these pictures are NSFW!!!!!
This goes doubly true if you like other netizens who say "ahoy matey"....especially those ones with such delicate constitution
DO NOT ENTER!
There will be NUDITY
my FJ40 is NAKED!
and other then showing a bit much underside
isn't too bad... I was concerned after digging 1/4" of bondo out of the rear corner
that said, I may have to find a fender solution
and I started welding holes tonight.... I think I'll keep the dehumidifier running in the shop and leave it naked while I fill all its holes
Today has been a nightmare, and tonight's work wasn't any better
I got the clutch on
and think I'm going to go with a pull-style hydraulic clutch..
then the problems started. So I first started with the hydraulic slave cylinder. I think I figured out why I has having so much trouble in my Corvette - the outlets I think were hitting on the housing - but only occasionally (hanging up on ribs).... I noticed it on here... so I spent plenty of time putzing about trying to make that work. Then went to the throwout style - and ran into another problem, I thought I drove the bushing in far enough (mind you, this was the 2nd bushing - yesterday I got reminded that the NAPA SKF version is too big and won't go in - I had this problem on the Corvette too)... this time, I though I hit it to bottom (felt like) but then dismissed the "why is it out a bit?"
and all the shops I use for work are busy - which is good because it means they do good work; but aren't so good about getting the work done as fast as promised (or I'd like)... oh well.
my wench arrived
just enough room to do a pull-style hydraulic clutch
the correct sensor arrived (e-speedo)
and the drive train is in....
and my wiring arrived for the TBI - what a helpful group of people (Howells)
I know this doesn't seem to show much, but actually, it's a big step
it means the pinion is in permanently and I can measure for driveshafts and axles (ordered the axles on Friday, will order the driveshafts on Monday)
so the rear springs from a rubicon are a bit soft, but the front springs seem to be pretty close
you'll note my multi-colored zip ties which hold the shocks in place
so this picture is more for the driveshaft folks, but the driveshaft is 19 1/2" long, it has a 23* angle (max 33*) but the pinion and the output are 8* opposite each other which brings the actually degree difference to a reasonable 16* (for a short wheelbase 4x4, that's doing pretty good).
I'll pull the rear differential out in the next day or two and paint it.... gotta be pretty too
front hp 44.... the fronts are 1310 u-joints... I figure that's the cheap fuse in the system - I may have to scallop the cross member for clearance - if I do, I'll add a mid-hoop just so bad things don't happen if the u-joint breaks
twin stick too
now we're getting somewhere
no picture of the first of the brackets welded in place - but it is and I have to fab a couple inner brackets then paint the weld away
on to the bare metal - spray with phosphoric acid
then rinse
same with the hood
I also got onto removing the cowl vent... I figure I'll get that done, ground down, then cut the dash and dowse it all with epoxy primer... maybe tomorrow after work I'll get the rear differential painted and the hood too. The side panels need to be cut and I'm putting different markers in them so there's a bit of fab before they get primered, the tailgate is going to be a one-piece that hinges at the bottom with a ladder attached to it that will double as a molle panel
continuing from yesterday
I ordered the driveshafts - so that should be the last of the big parts.... now the nickel and dime crap (like window seals and such)
shock mounts (at least half of them)
and the other half in their rough form
epoxy primered the hood
and the fillers (and had a bit of trouble with it - I shouldn't have etched the metal)
the firewall I didn't etch, I just blew the paint on.... it went on beautifully
live and learn - the etched parts still aren't dry to the touch, the firewall is though it was last painted
and I finished filling the hole in the cowl
thanks
brackets
brackets installed
sway bar
starting on the clutch
turn the bar around the other way
GM A-bodies have a sway bar attached to the lower control arm that works pretty well - thus, copying what they did is the idea behind this
flexy check for clearances
full compression
weld on clevis attachment points
burn finger.... time for new welding gloves (ouch)
FJ40 standing on its end
now with primer
and inside too
so the axle was a bit long, and Nitro suggested shortening it. It's close... I admit being concerned about the length of spline engagement but I don't do axles for a living and these have a lifetime warranty...
you can see where the seal is now with the shortened shaft
next up, finishing up the underside so I can mount it back on the frame (and gain some room back)
on the lower ball joint, I had to clearance a bit
Damn. Tough break on the axle shaft. I keep Mr. N's axle shaft chart on hand at all times. Then I adjust the housing accordingly so custom shafts are never needed. The D44 has been made in so many widths, that you can pretty much chop them to any width in 1/2" increments, and then use the appropriate shafts from the chart.
A lathe would be nice to cut a longer seal journal....those can be pesky if it's not completely concentric. At least you didn't have to cut a new C-clip groove!
