scoreh3
I was just putting it out there as a choice . I think NFAB or KC makes a straight tube with 4 light tabs too. The straight bar just looks like a good way to smash your lights .
Kyle
Santa Clarita, CA
Hmmm well I'm not sure what I'm going to end up doing now. I'd like to put 4 vision X light cannons on the front. Planned to do two 6.7inch ones on the outside and two 8.7inch in the middle and then have euro beam covers on the 6.7inch ones to have wide angle light then the two for crazy throw
scoreh3
The Thor bar puts them up higher and adds a little more protection . Now a really good set up would be one like Chris has on his 3 .
Kyle
Santa Clarita, CA
Nice vid. BTW, what headlight & foglight bulbs are you using? I like the "white" colortemp.
local shop here sells em, generic 5k 35 watt hid's the fogs dont match the headlights at all though in person when you look at it, even tho they are the same bulb color, i plan to take them out and do LED in fogs and headlights so they match.
All you bums talking about CVs and other things not working in other threads must have jinxed me....found my drivers side cv is torn, grease everywhere, inner one is about to tear as well. So guess I have that to take care of here soon.
High Five H2
West Texas
Same here. No idea what happened.
Can007
Palmdale, CA
Getting ready for the hot summer... Just replaced the thermal stat, water pump, serpentine belt and installed aluminum radiator.
Kyle
Santa Clarita, CA
I have been in communication with Chris and will also install 2 pusher fans.
Yea I plan to do that as well, I'm going to have a shop do the water pump and belt and radiator, and then once it's back in my possession i plan to do efans for the radiator and for my trans cooler, all controlled via an spods touch screen system
Just got my sPod in the mail this weekend. How did you run the cable through the firewall? How did you mount the screen to your dash? Where did you mount the controller under the hood? I did a test fit mounted on top of the air box, clears with 1/4" to spare.
USMC_TOP
Muir Michigan
In the shop for a head gasket minimum. Lasted 137,000 miles. I am not happy. Heading to Detroit tomorrow at look at an 08 H2
Kyle
Santa Clarita, CA
Hole in the fire wall and then mounted the control unit on top of the fuse box cover, then the touch screen is mounted via a modified right angle bracket mount that they make that you can either screw to the dash or 3M tapes to the dash, it helps that they are literally my neighbors at work, we all hang out and stuff. I may work with them to design some more hummer related stuff since they only focus on jeep and toyota stuff mainly.
Kyle
Santa Clarita, CA
Just yankin you. I got four of em left. That's the first time I've ever seen one on a stock bumper.
Hey CJ are the tabs for the lights easy to grind off and re weldable to a different position? I'm worried the lights I'm going to be ordering will be to "fat" and hit the grill because ill be mounting them upside down so they are inside the bull bar instead of on top.
