zebra
cold & windy
so at 187k miles, the leaking steering rack finally got replaced... along with the front output shaft seal of the t-case (which had been slinging fluid everywhere for a few thousand miles).
and mid-job, we recognized that the ball joints & passenger-side front diff bushing are shot. got new ones + control arms & wheel bearings on the way for next week. that's a lot of fixing money for a truck that ain't worth a whole lot nowadays :(
Cheaper than a new one by a long shot and you're good for another few years.
Will be busy next weekend replacing Johnny Joints. Sand Hollow prep has started.
H3Hummer
LUXEMBOURG in EU
So this time my Hummer got some new chassis protection, rust treatment an wax at front, after the body mounts on driver and passenger side got cleaned, rust treatment and new all round welded ...just in case ;)
Then painted again all in black with ...eh like Rustoleum paint
Now my Hummer is 10 years younger again :cool: made by my professional Buddy , in his garage (he loves oldies and US trucks)
Few pics
woodwardsh3
Oakland Co. Mi.
Just got home from a road trip to Quebec 9 hour drive 1 way to pick up the rock sliders from citiboy. And then today I Removed the chrome step bars and the factory plastic fender liners for tomorrow's trip to Krown rust preventive appointment. Then I will be mounting my new OEM rock sliders this weekend.
clifford_H3T
Georgia
Installed marker lights on the windshield trim.
Found what was squeaking from the rear in Sand Hollow. Rear pads are worn down and uneven. Both lower slide pins were seized, and the rubber rings had deteriorated and stopped the pins from moving.
Ridinhigh1500
Raleigh, NC
Re doing the wire loom and upgrading the battery cables to 2 gauge.
Some concerns with PowerStop calipers. Supposed to be pressure tested but leaks with no brake pressure. Last set had early failures too, quality has dropped.
woodwardsh3
Oakland Co. Mi.
Started out replacing a wheel bearing / hub assembly, after buying 4 new tires. But my OCD kicked in now I have new inner and outer tie rods and boots, 2 lower ball joints, 1 upper control arm & ball joint. 2 new bump stops, 4 new shocks, 2 new CV axels and seals, New front diff mounts, Brake pads front and back, Man I wish I could just leave well enough alone. I still have to reassemble more than half of it. Everything takes longer when you get old. the mind is still 25 the body just caint keep up with it. Probably take me a couple more days to have everything back to gather. Should drive like new soon.
atvspeed4
massachusetts
We were maintaining around 10 h3s at one point and were exclusively using powerstop z36 full kits with calipers as they came due for new brakes. Were were swapping over to powerstop and new stainless hardlines and soft lines with full fluid flush. About four years ago there was a national shortage of H3 powerstop calipers and they must have switched to a new manufacture as we started having issues with them leaking and eventually seizing. No good replacements unfortunately since then. Same issue with the "OEM" calipers from GM parts
