cbetts
NERD!!!
- Rancho Palos Verdes, CA
Look what I got today!
One question . . .
The u-bolts a narrower than the holes on the mounts. Is it okay to widen the u-bolts for them to fit?
One question . . .
Are those u bolts new or are u reusing them?
So... will this work with the Rancho lift, or will we need to make some adjustments in the shackles? I'm planning on ordering a pair when I get some budget funds... do you need any measurements on the Rancho shackles? I also added a leaf to the pack which fixes some Rancho issues, not sure if that matters for these.
Okay, I had the new mounts put on today and chose to put the OEMs back on. I have a safety concern after seeing them on my truck.
The tabs outside of the springs started to bend upward once the proper torque was applied to the u-bolts. Also, the u-bolts sit apart more, just barely grabbing the re-enforcement on the top of the axle.
With the type of wheeling I do, it was recommended by my mechanic to put the OEM mounts back on. I am not sure what needs to be modified to make this work properly. Maybe some of our seasoned metal workers can give some insight.
I would also like to add that I intentionally designed the High Clearance Leaf Spring Mount to deflect a bit so that you have better chance seating the U-bolts better on the axle braces.
I don't mean to play the bad guy here, but it's time to speak up. The more I look at this plate, the worse my thoughts of them are. So, the spring pack is pushing down and the axle housing is applying upward pressure on the u-bolts and plates. Everytime you hit severe bumps in the road, there is risk that the tabs on side of the plates could get bent upward. Over time, the sides will be bent up enough where the small leaf spring indention that goes into the hole in the center of the plate is no longer in the hole; thus allowing the axle to move side-to-side sperate from the leaf spring pack. Cbetts has noted that there is already barely any of the u-bolt resting atop the perch on the axle tube. Thus, barely any play in this assembly is going to allow the u-bolt to slip off the perch and now the axle is flowing freely on the spring pack. An additional concernis that each time the sides bend upward (given that they were designed to bend), the nuts will become looser and increase risk even further.
Okay. I will give it another shot. Maybe I can talk 06H3 in giving me a hand.
No need to try and talk me into helping. Id love to help! lol
trust me when I say that you got thiso all wrong, they used an impack gun and cranked the piss out of the bolts, and when I say it bends it is nothing like you're talking about.
Well, that's what you said last time I warned that the design was prone to be bending. No worries, time will tell so I will sit back and watch.
Considering that you guys thought you needed 1" thick metal to support a shock mount, I can't say that you're the authority on engineering requirements
I think you MIGHT be fond of overbuilding something a bit too much:sly:
Btw, the time to speak up would have been when he was asking for input, rather than too late, after products have shipped.
If your product was still around, there probably wouldn't have been the need for this one.
Sent from my A200 using Tapatalk 2
