So! Yesterday, nothing could wife the smile off my face.
Engine bay populated, and tranny bolted right up.
Had to buy a new starter, and ended up getting new AC lines. Heater hose was out of stock so I'll either get that online, or completely forget about it. Never used it its like 5000 degrees out here, and winters are mild.
Now for the tuning, Jamie had reflashed my PCM/TCM to take a V8 tune.
I have TWO V8 tunes at my disposal.
1) Stock V8 tune provided by Jamie, said it should load right up.
2) Fine tuned file for the V8 currently in my truck.
Both tunes are for the alpha, so I need to do the following:
a) reflect 4.10 to 4.56 ratio change.
b) remove O2 codes caused by the rear O2 sensor delete
c) Reconfigure fan settings. I have 2 fans and one relay for them. I can wire them to work as one but would still need to remove codes and set temperature parameters.
d) after factory flash I'll need to learn the crank angle , otherwise a po315 code will come up.
A and B are straight forward, I'll be researching the whole compare/copy option. BUT I do not know what C and D are all about.
Fun fact: Buying an Alpha, rebuilding the tranny and rehearing to 4.56 would have been cheaper by $3,000. Not complaining, just saying.
