Hummer h2 build ideas
Bmonts h3
Mobile,al
Forgot to add but plasti dipped upload more photos tommorow of what the 2 looks like now
Bmonts h3
Mobile,al
My h2 now, I’m thinking of getting some stickers calling it the great white on the back and putting a sticker of a great white not very big and on the front bumper around the winch space going out wide and putting shark jaws with teeth anyone else think this would be cool or just leave it how it is?
Naw! Could go Birch White Maffia [emoji23].
Nice looking 2 though [emoji106]
Sent from my iPad using Tapatalk Pro
Bmonts h3
Mobile,al
Hit 8of 11 grease points today changed the oil added shackles and took my radio out to send off to get unlocked
TonkaTank93
VA, USA
I am running 38s with no lift. As far as mods, I run front and rear lockers and 4.56 gears, Dynatech Headers, DIY on-board air system, modded the rock rails to bump them out 2", Kryptonite centerline and tie-rods, and many more I am forgetting about over the years.
How are those kryptonite tie rods holding up? The warranty makes it very tempting to buy them.
Big2dabank
Central Florida
They have held up very well. 6 or so years and I am just now needing to replace the inner and outer rod ends working with them on the warranty claim, but I bought a new set of inner and outers to avoid waiting for them to receive the worn parts and send back the new ones. Absolutely no complaints so far, very solid, but you’ll definitely want to add the center link and supports if you wheel. The 38s put a lot of stress on the steering.
TonkaTank93
VA, USA
I'd imagine 38s put them through the stress tests. I'm running 40s but I haven't upgraded any of the steering components yet so I don't want to push it.
Where did you get the center link and supports from? Kryptonite's web site?
Big2dabank
Central Florida
I got everything through the Dmaxstore before kryptonite started selling them direct. You can get the full package with the center link and support brackets from either one, I think the price is about the same. Dmaxstore sent me directly I got the to kryptonite for the replacement rod ends and I am dealing with them on the warranty currently.
Bmonts h3
Mobile,al
Reaper rock lights
MilamJR
Alabama
Thanks. I have a rear tire carrier. Do you think it would work?
MilamJR
Alabama
Thanks. Do you know how far it sticks out so I can try to determine if the jack will be an issue.
hummerologist
Marz
Hi MilamJR, the fender flares are by (E&G) the Wide Version and the awning is from a local brand similar to the ARB brand but slightly longer and wider
MilamJR
Alabama
Thanks. I have been considering the E&G fender flares for a while. How much additional coverage do they supply and would you recommend them.
hummerologist
Marz
you get additional 3" of coverage, equally they're solid and functional and transform the looks of our H2'z. my H2 is on 38"X13.5 Toyo Mud tires and they're fully covered.
