FJ4overland
Panzer07
Ontario, CA
I bought another 350 short block... I've neither the funds nor the patience to do another upgrade before I wheel this thing[/FONT][/COLOR]
and it's out
a bit of carbon, but nothing too untoward about the heads. I'll check for flat, clean, then reuse on the new bottom end....
​Sunday will be clean parts, paint, and maybe finish a few wiring projects along with some header-beating....
somehow I feel I've trod this path before.
cleaning and testing
so I finally got around to doing the mod I've been planning on my parts washer... I added a pump (actually 2 pumps, the first didn't put out enough volume)
then onto flattening flanges on the header
I also did a lot to make sure the bolts fit better and that I can install and remove the #1 spark plug without having to remove the header.... bonus
I also gave the gasket a bit more of a chance to work by building up the edge on the header
and more test fitting
that's all folks...
So a couple years ago, I built this - a divideable kennel for my wife's dogs
it always was a work-in-progress
so as you saw a couple weeks ago, I built new kennels for the Heep.... today I started installing them
first was clean up some wiring
and move (again) the speaker
so here is what it looks like
it gives my wife some flexibility - she can haul one dog, or two dogs and her older dog gets worried when she can't see where she's going - so the kennel allows her to be in front and can access the front seat through the middle
this also gives the benefit of when she loses her keys - that she still get the dogs out - you can get into the front, but you cannot access the rear gate without keys... which was a problem because that was the only way to let the dogs out....
so I had my wife load her heep back up....
I'm going to do a drawer and a shelf and it should be done except for the extras
I know some think it's animal abuse to build a smaller cage for such a large dog - actually, it's only people who want extra space for a dog, it's all about defensible space. Not just that but should bad happen and they be in an accident, not having a lot of room is much safer
Buick motor off the stand
new 355 short block on the stand
The guy gave me a 4 bolt main, roller block instead of the 2 bolt....
grey is the color this time
I like what I got, and the shop who did the work was immaculate - always a good sign.
not much to show, wired the motor and hooked everything up... no noise yet, but I'm very close.
one of the things I did was drill a bleeder hole in the thermostat - for no other reason but to make filling it easier
and wired.... a couple minor things to do - hook up throttle cable, put in a couple bolts in the bellhousing, and tighten up the exhaust pipes.... oh and rotate the distributor 180.... dagnabit.
on with making it go, again
oh what a pain - I was right, I was about 45 degrees off on the timing...
look at that, oil pressure
which makes me a bit irritated at the dakota digital gauges, they didn't work, I checked the wiring and have tested everything and it should have worked. The only thing that might be wrong is the connection is fault... but even then....
and back to wiring
so basically I'm back to where I was a couple weeks ago. I'm leaving the front off while I finish the wiring....
So after a whole bunch of testing I've found the sender is bad.... would have been nice to have a sender when it dropped oil pressure.... ah well, at least the sender is covered by the manufacturer warranty (it's like 90 bucks)
onto more
underhood lighting
and the dash lights up.... even turns on a few lights
​getting there... I should have it back on the road and wired Sunday.
Shifter handle
note the Toyota Racing Division shift knob....
and then there was wiring.... and fixing a problem.... and 4 hours went by....
but I figured out the issue with the compressor wiring.... my goodness does that fill up the tank quickly - and drain quickly.... some bubble testing will happen soon
some of the wiring, one of the radios
then throttle cable
now it's starting to look like something... what, I dunno, but something for sure
gauges are in, hopefully permanently
and the oil pressure gauge works, sigh
More Jeep parts - mirrors installed
next is a dash (bar), and a harness bar.... I'm not using these seat belts...
and another nose shot (after turning it around)
more crossing Ts and dotting 'i's
mirrors attached
still working on the speedo.... I swapped out the 3 wire for a 2 wire and still no bueno
and wired the hood lights
along with removed the squealing alternator... I hate replacing it simply because of a bearing... but it appears that is exactly what I'm going to do
Speedo now works
the issue
so here's the deal. Novak builds the 32 spline output housing. They send it to you assembled. When I bought mine, they'd just got them back into stock and there was, I found out now, a mistake
When they machined the hole for the speedometer sensor, they didn't machine it all the way through - so it keeps the magnet at least 1" away from the reluctor wheel. It needs to be 1/16" to 1/8" away. So some creative grinding had to occur.
and there it is installed... and it works
what a pain.
also checked the "attach the sway bar" box
crappy picture, but installed
and I came up with a air cleaner for the compressor
I simply used a crankcase vent filter - it shoudl be more than enough
Good news, the speedometer works, the temp gauge works, the oil pressure gauge works. Unfortunately the oil pressure is low and the coolant temp is a bit higher than I want... it's also louder than I want.... that is an issue that I will solve in addition to the others.
last night was exciting too, painting widgets
the bench is almost clear... glorious
hmmm, nice drive in the country, nice time to coat the undercarriage with purple oil
oh yes, and wheels too
both of them... annoying because I thought I'd solved this one
oil leaks are because I don't have a vent tube on the transfer case.... as it's as high up as I can get it, I have to get creative on how to run the tube.
gratuitous under carriage shot
We're going to cover a lot of ground tonight, so grab a beverage, get comfortable... and here we go
as I mentioned before, I have adjustment in the panhard bar, a change happened
next
there's a cooling system issue, but this doesn't solve it. It simply allows me to shut off the heater during the summer
​and I noticed one problem - no coolant in that line. there should be
So I filled the system, and it was at least a quart low with no fluid in the reserve canister…. Hopefully this fixes it
Then worked on the center console
Why they didn’t have an outlet inside is odd, but it’s fixed now
And circle back to a question of how the defroster works… here it is
Then onto installing the bikini
Nice n tight top
Then onto starting the dash
this won’t be the final version, but it is for testing to see where I want it to be. Eventually it’ll have a shield in the middle, lights and maybe a touch of padding
Rocksliders/step
Maybe this?
My motorcycle is feeling lonely
Time to make the exhaust less redneck
I put the insulation on top because the top of the muffler will get up to 500 degrees
but it wouldn't last long on a mud day, so something a bit more permanent was required
to quiet the exhaust a bit I'm going to reduce the outlet size, but in my tons of drop steel, no 2" stainless pipe... ugh. I'm going to make the insert removeable, but first I need to build the slider/steps so I know where it should come out. who knows, I may even make the exit square....
work all day, hard to tell a difference
first some dash action
weld blankets are awesome
and a shelf
and some handle fixing
then some CB work
seatbelt fix
fixed
and music
my goal was get the sliders done... oh well, I'm closer
